hesitation and low idle
Old Oct 30, 2008 | 05:47 AM
kt93accord's Avatar
Default Need your feedback
I own a 93 accord LX and recently it started missing like the car was running out of gas. My fuel light was not on and I had 1/4 tank of gas. Also the car idles real, real low almost hitting zero at a stop. Is this idle normal for an automatic? Do you guys know what might be causing the car to studder? Oh, the car has 160,000 miles. Thank you for your assistance.
Old Oct 30, 2008 | 07:00 AM
Mr Yamada's Avatar
Default Re: Need your feedback (kt93accord)
Has any type of main't ever been done?
Clean around the throttle plate with carb cleaner.
Unplug the IACV while at idle to see if it is working, also the screen on the IACV can get clooged with soot.
If it is running rich pull the vacum line from the Fuel Pressure Regulator and check for raw gas, IE ruptured diaphram.
Old Oct 30, 2008 | 07:58 AM
accord_raffi's Avatar
Default Re: Need your feedback (Mr Yamada)
I agree with Mr Yamada. Clean the throttle plate and the IACV. There's a nice write-up in the FAQ section.
Old Oct 30, 2008 | 08:43 AM
kt93accord's Avatar
Default Re: Need your feedback (accord_raffi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord_raffi &raquo;</TD></TR><TR><TD CLASS="quote">I agree with Mr Yamada. Clean the throttle plate and the IACV. There's a nice write-up in the FAQ section.</TD></TR></TABLE>
Thank you and Mr Yamada too........I'll check out those areas now.
sumuno
Aug 1, 2014 04:30 AM
z0mby
Oct 22, 2011 04:32 PM
curtie94
Aug 4, 2011 08:03 PM
xkwzt21
Nov 17, 2007 11:54 AM
GSRwBOOST
Jan 10, 2002 11:19 AM
