Engine Idle
Old Aug 1, 2011 | 05:53 PM
curtie94's Avatar
Default Engine Idle
1991 Honda Accord idle is at 900 RPM when it usually idles at 750 RPM. Car runs fine other then that. A/C is NOT on.
Sometimes if I put my foot behind the gas pedal and pull back it drops. What can cause the idle to raise like this.
It doesn't always do this!
Old Aug 2, 2011 | 03:15 PM
poorman212's Avatar
Default Re: Engine Idle
A sticking tb or cables?
Old Aug 2, 2011 | 06:39 PM
curtie94's Avatar
Yeah thats what I thought because my gas pedal sticks when I stop, I have to hit the pedal hard for it to go agian. I cleaned around the intake, it is carboned up. After I clean it, it runs great but soon after does the same thing. I use carb cleaner to clean it.
It has a cold air intake does that have anything to do with it?
Old Aug 4, 2011 | 04:01 PM
poorman212's Avatar
? Might? Can you get someone to push/release the gas as you watch the cables and that to see if something is binding on the outside.......then there could be carbon and that on the inside of the tb that could cause the butterfly not to close all the way.
Old Aug 4, 2011 | 04:41 PM
curtie94's Avatar
I cleaned the TB, the idle was fine but now after one drive the idle is back to 900 RPM.
Old Aug 4, 2011 | 05:52 PM
chikin pickle's Avatar
You got a vacuum leak brah.
Driving with part throttle pulls more vacuum than at idle, opens the leak path.
Old Aug 4, 2011 | 06:33 PM
curtie94's Avatar
where would you look first for a vacuum leaklike this.
Old Aug 4, 2011 | 08:03 PM
nus_dogg's Avatar
Just spray carb/brake cleaner around the intake manifold and all of your vacuum hoses to see if the idle will change.
kitt
Apr 29, 2010 11:57 AM
fresheg760
Jun 7, 2008 06:33 AM
bdubnyc
11
Apr 18, 2008 09:39 PM
Poey2
Nov 15, 2007 08:04 AM
ahc'monracing
Oct 22, 2002 07:38 PM
