rebuilt engine will not rev past 3000 rpm's
Old Oct 29, 2008 | 04:40 PM
ren1's Avatar
Default rebuilt engine will not rev past 3000 rpm's
I've searched for hours and can find similar situations but not the same. I just rebuilt and installed a new engine for my 1997 lude (sh) and everything works great except the engine will not rev over 3000 rpm's. It is the same engine with the same ECU. The car idols perfect and I have checked and can't find any sensors that I missed. The engine light does not come on so I'm assuming there are not error codes and I'm out of ideas on what to do to get my car to rev properly. any ideas would be greatly appreciated. Thank you very much for any responses.
Old Oct 29, 2008 | 05:01 PM
92hondalude's Avatar
Default Re: rebuilt engine will not rev past 3000 rpm's (ren1)
knock sensor?
i doubt it would make it not rev past 3k but i know it monitors knock after 3k so maybe.....
Old Oct 30, 2008 | 01:00 PM
Scheizty's Avatar
Was any work done to or around the distributor?
Old Nov 1, 2008 | 07:19 PM
ren1's Avatar
Default Re: rebuilt engine will not rev past 3000 rpm's (92hondalude)
Thank you very much for the responses! I will definately check the knock sensor but I don't know where it is? Where abouts can I find it? and once I do, do you know how I can check if it is still good?
As for the distributor I don't think any work was done to it. I know my re-builder put in new plugs but I don't know for sure about the distributor. I can call and find out though. Why do you ask this? What could be wrong with the distributor that I should check into?
Thanks again for the responses! I really appreciate it!
Old Nov 2, 2008 | 08:03 PM
ren1's Avatar
WEW I got it! It was the TDC/CKP sensor. It was in the right place but apparently I did not push it in all the way and the connection was no good. I pushed it in properly and now the car runs and revs perfect! Thanks for the suggestion though! I really appreciate it!
Old Nov 2, 2008 | 09:27 PM
98vtec's Avatar
moderator emeritus
an unplugged CKP/TDC connector would throw a light....
ekcivic2
Jun 17, 2013 10:07 AM
meat27
Jan 18, 2012 01:46 AM
Ecky
May 21, 2011 01:57 PM
Acclude
Nov 12, 2002 09:04 PM
Ideal R
Jul 27, 2001 06:55 AM
