94 accord help??
yeah the dash lights dont work either and no i havent checked the wiring on the lighter but the lighter has been out for a while and the dash lights just went out
Assuming the Small Lights Fuse is good (under hood) then most likely the dimmer switch is bad. If it doesn't work then the lights won't work.
As to the cigarette I'd look at the wiring first, it's possible it's loose or not even attached on the back end. Does the small light in the ash tray work?
pollardr84
Jan 20, 2012 03:14 PM
silvercrxsi88
Oct 17, 2003 08:32 AM
