turbo
Old Oct 29, 2008 | 08:53 AM
lilshady6796's Avatar
Default turbo
ok if i redo my engine with.........pistons, valves, rods, valve spring, valve retainers, cam shaft, crank shaft, all fuel delivery, flywheel, clutch, cam gear, timing belt, now if i do this will i loose lots of oil and screw my motor up with 10-15 lbs of turbo cuz i was told "no matter what i do with any motor it will still loose oil and prolly blow up" is this true
Old Oct 29, 2008 | 08:58 AM
davefromPA's Avatar
Default Re: turbo (lilshady6796)
what motor? what turbo? 10-15 psi on one turbo is not the same as 10-15 psi on another. post in forced induction.
to answer simply, your motor will be as fine as the tune you get for it.
Hut94ex's Avatar
WoW...:-(
Old Oct 29, 2008 | 09:53 AM
Schister66's Avatar
Man U FTW
You already have another abomination thread like this in FI...please dont post multiples of the same thread.
lilshady6796
Oct 31, 2008 03:29 PM
FHTB20allday
Northeast (Sales)
Mar 6, 2008 06:42 AM
lsvtec4door
Dec 13, 2003 09:02 PM
quik sol
Dec 13, 2003 04:03 AM
Thrillhouse
Jul 20, 2002 08:41 AM
