turbo
turbo
ok if i redo my engine with.........pistons, valves, rods, valve spring, valve retainers, cam shaft, crank shaft, all fuel delivery, flywheel, clutch, cam gear, timing belt, now if i do this will i loose lots of oil and screw my motor up with 10-15 lbs of turbo cuz i was told "no matter what i do with any motor it will still loose oil and prolly blow up" is this true
Re: turbo (lilshady6796)
what motor? what turbo? 10-15 psi on one turbo is not the same as 10-15 psi on another. post in forced induction.
to answer simply, your motor will be as fine as the tune you get for it.
