Machine Work on GSR block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruffrhyder »</TD></TR><TR><TD CLASS="quote">82mm is max on stock b18 sleeves
x2 same thing i've heard. 81.50 is a popular overbore just so you don't waste the block on the first build.
</TD></TR></TABLE>x2 same thing i've heard. 81.50 is a popular overbore just so you don't waste the block on the first build.
word. boring it to the max desreases the amount of heat that can dissipate from the cylinders. i would go .050 over and run darted sleeves. cast iron preferably. but hell its your motor. lol i just dont want you to be the guy all those domestic [pejorative]s see on the side of the road and laugh about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">If you're running NA, then overboring to 82mm is fine. If you're planning to boost, then 81.5mm is the max</TD></TR></TABLE>
spoonhatchblack
Dec 5, 2005 10:36 PM
boostedcivicsir
Nov 26, 2005 08:44 PM
spoon23_JDizM AkA SpOoN20
Dec 7, 2004 03:43 AM
