Fresh 2000 GS-R swap into EG rpm problem..Please Help!!!!!!
Old Oct 28, 2008 | 05:57 PM
SOHC_2_DOHC's Avatar
Default Fresh 2000 GS-R swap into EG rpm problem..Please Help!!!!!!
I just finished installing a 2000 GS-R motor into my EG hatch and everything is working fine but the only problem that i have is that my Rpm on my guage cluster is jumpy from 1000-1500 when on idle but it doesnt effect the motor or idle. What do you guys think it may be because i checked all plugs and everything is in and no check engine lights are on. Please Help!!!........
Old Oct 29, 2008 | 03:22 AM
coupej1's Avatar
my friend had the same prob and it ended up that the ground on the thermostat housing was loose.
Old Oct 29, 2008 | 10:48 AM
Default Re: (coupej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coupej1 &raquo;</TD></TR><TR><TD CLASS="quote">my friend had the same prob and it ended up that the ground on the thermostat housing was loose.</TD></TR></TABLE>
Ok ill be sure to check that out. Thanks!!
Anyone have any other suggestions!!
Old Oct 30, 2008 | 04:27 AM
coupej1's Avatar
did that fix the prob?
Old Oct 30, 2008 | 11:42 AM
I checked that ground and 2 more but its still the same.
Im going to pull the cluster out and make sure the clips are in because my buddy pulled it out to install the throttle cable.
Old Oct 30, 2008 | 11:56 AM
dam_teg98's Avatar
Default Re: (SOHC_2_DOHC)
i had that problem once and it ended up being the idler adjuster skrew on the throttle body kept backing out. Just a suggestion.
Old Oct 30, 2008 | 05:35 PM
coupej1's Avatar
my next guess would be something inside the dizzy is going bad.
Old Oct 30, 2008 | 05:59 PM
Default Re: (dam_teg98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dam_teg98 &raquo;</TD></TR><TR><TD CLASS="quote">i had that problem once and it ended up being the idler adjuster skrew on the throttle body kept backing out. Just a suggestion.</TD></TR></TABLE>
Ill take a look thanks
Old Oct 30, 2008 | 06:01 PM
It has to be something because its really odd and it doesnt effect the idle in any way.
Old Oct 30, 2008 | 06:39 PM
hybridmath's Avatar
its the idle air contol valve not the dizzy
Old Oct 30, 2008 | 10:28 PM
Default Re: (hybridmath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmath &raquo;</TD></TR><TR><TD CLASS="quote">its the idle air contol valve not the dizzy</TD></TR></TABLE>
I dont think its that because my idle is fine, it just effects the guage cluster not the car. It just started with the new swap that i just did last weekend. I had a JDM D15b Vtec in it and had no problem with the guage cluster. Its Wierd and fustrating!!
Old Oct 31, 2008 | 03:08 AM
coupej1's Avatar
its not the idle air control its the dizzy!
Old Oct 31, 2008 | 08:23 PM
its not the idle air control its the dizzy! </TD></TR></TABLE>
Ill look into that forsure!!
Lippe019
Jun 21, 2007 01:56 PM
steve_meyer
Audio / Security / Video
Oct 28, 2004 02:34 PM
Mr HYDE
Jul 17, 2003 12:26 PM
