Del sol wont start, has fuel.
Old Oct 28, 2008 | 09:47 AM
delsolnewkid's Avatar
Default Del sol wont start, has fuel.
My del sol wont start, i tried replacing the ignition switch, no change, i can jump the starter solenoid connection and the car starts fine, so it isnt the starter. what can i check between the ignition switch and the starter? is there a starter relay? where can i find it?
Old Oct 28, 2008 | 10:34 AM
94hdelsol's Avatar
under the drivers side , behind hood leaver, up top look for gray rectangle box has brown top to it, brown harness ( i think ) attached to it
Old Oct 28, 2008 | 10:41 AM
Relic1's Avatar
fresh swap? daily driver that has always worked fine?
main relay would be my guess for a car that's always worked till now, but it could be a lot of things if it's a fresh swap.
Old Oct 28, 2008 | 11:26 AM
Default Re: (Relic1)
correct me if i'm wrong, but i thought the main relay mainly dealt with the fuel pump, does it actualy affect the starter signal?
Old Oct 28, 2008 | 12:07 PM
Relic1's Avatar
the main relay is actually two relays, one controls the fuel pump the other throws power to the ECU, injectors and a few sensors.
Check the main relay after you check for power at the starter cut relay.
I have not heard of a lot of starter cut relays going bad, but main relays I hear of a lot.
Old Oct 28, 2008 | 02:18 PM
where is the starter cut relay?
Old Oct 28, 2008 | 02:28 PM
Relic1's Avatar
Default Re: (delsolnewkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolnewkid &raquo;</TD></TR><TR><TD CLASS="quote">where is the starter cut relay?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hdelsol &raquo;</TD></TR><TR><TD CLASS="quote">under the drivers side , behind hood leaver, up top look for gray rectangle box has brown top to it, brown harness ( i think ) attached to it
KCVBALL17
19
Oct 21, 2015 11:25 AM
Eversonc85
Jul 18, 2015 08:01 AM
Time Ranger
11
Aug 4, 2014 03:07 AM
91tegrals
Feb 12, 2012 09:03 PM
DsCivicEx
Feb 5, 2004 09:16 AM
