Del sol wont start, has fuel.
My del sol wont start, i tried replacing the ignition switch, no change, i can jump the starter solenoid connection and the car starts fine, so it isnt the starter. what can i check between the ignition switch and the starter? is there a starter relay? where can i find it?
fresh swap? daily driver that has always worked fine?
main relay would be my guess for a car that's always worked till now, but it could be a lot of things if it's a fresh swap.
the main relay is actually two relays, one controls the fuel pump the other throws power to the ECU, injectors and a few sensors.
Check the main relay after you check for power at the starter cut relay.
I have not heard of a lot of starter cut relays going bad, but main relays I hear of a lot.
Re: (delsolnewkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolnewkid »</TD></TR><TR><TD CLASS="quote">where is the starter cut relay?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hdelsol »</TD></TR><TR><TD CLASS="quote">under the drivers side , behind hood leaver, up top look for gray rectangle box has brown top to it, brown harness ( i think ) attached to it
Time Ranger
11
08-04-2014 03:07 AM
91tegrals
02-12-2012 09:03 PM
