A/F Gauge Wiring
Old Jul 29, 2002 | 06:52 PM
IgniteTeg's Avatar
Default A/F Gauge Wiring
Did search but no good. Was wondering which is more accurate for the a/f gauge to be tap at. The o2 sensor or the ecu? Does it matter? Any difference? Will tapin at the ecu make it less bouncy and more accurate or something? Thanks.
Old Jul 29, 2002 | 06:59 PM
RC211V's Avatar
Default Re: A/F Gauge Wiring (IgniteTeg)
which a/f gaugfe you got?
Old Jul 29, 2002 | 07:00 PM
RC211V's Avatar
the autometer A/F gauge is really inacurate.
Old Jul 29, 2002 | 07:17 PM
IgniteTeg's Avatar
Default Re: A/F Gauge Wiring (JDMintegGSR)
yeah, i know that but does it matter if its tap in the ecu or the o2 sensor? Which is more accurate still?
Old Jul 29, 2002 | 09:43 PM
Aaron M's Avatar
i noticed better readings at the ECU(might just be in my mind) but its better knowing there isnt wires running all around ur engine bay.
Old Jul 30, 2002 | 05:35 AM
metal-x's Avatar
Default Re: A/F Gauge Wiring (SilverB18C1)
I ran mines from the ecu had to use an wire extension to make it reach
tap it to the white wire with the red stripe
Old Jul 31, 2002 | 11:12 PM
IgniteTeg's Avatar
Default Re: A/F Gauge Wiring (metal-x)
wow so many tap to ecu. any feedback? Has anyone see any difference or more stable to tapped it at the o2 or the ecu?
Old Aug 20, 2002 | 06:41 PM
MikeMAN's Avatar
i tapped to both, and it SEEMED as if the O2 sensor took longer to get more accurate, whereas the ECU only took a minute or so....i just like not worrying about the wire getting snagged on something OUTSIDE the engine...
good luck
mike
Old Aug 20, 2002 | 07:24 PM
legendboy's Avatar
Default Re: A/F Gauge Wiring (MikeMAN)
There should be no difference.
Old Aug 20, 2002 | 08:13 PM
gsrvx's Avatar
New User
It may be inaccurate...but it will still give u a general idea of whether ur running rich or lean.
-Rod
Boosted 2L
Aug 1, 2005 07:39 PM
Project91CRX
11
Oct 6, 2003 11:41 AM
IgniteTeg
Jul 31, 2002 11:07 PM
REDBARON
19
Jan 10, 2002 06:39 AM
