shifter moves every time gas is released or pressed...bad motor mounts?
Old Oct 27, 2008 | 05:05 PM
pli's Avatar
pli
Default shifter moves every time gas is released or pressed...bad motor mounts?
so my buddy's em1...everytime you press on the gas and release it, the whole shifter moves like forward or backward (by a little). my guess is that its bad tranny motor mounts.
does anyone else know what other possibilities it could be?
they are stock motor mounts and has over 120-130k miles on the motor.
also, is it hard to swap out the old motor mounts? all it is, is just holding the whole motor up with a jack and just do each motor mount, one by one right? unscrewing each bolt and taking off the old mount, then putting in the new one?
thanks,
Peter L.
Old Oct 27, 2008 | 05:11 PM
fresh^eg29's Avatar
Default Re: shifter moves every time gas is released or pressed...bad motor mounts? (pli)
the back motor mount is really bad if that is happening. it makes the motor rock back and forth, so change it before you get grindings gears
Old Oct 27, 2008 | 05:17 PM
D16SiHatch's Avatar
Default Re: shifter moves every time gas is released or pressed...bad motor mounts? (fresh^eg29)
if its only moving a little bit then thats perfectly normal. if he's noticed a progression and its now moving a lot more than it used to, then perhaps the mount bushings have worn out.
Old Oct 27, 2008 | 05:30 PM
pli's Avatar
pli
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fresh^eg29 &raquo;</TD></TR><TR><TD CLASS="quote">the back motor mount is really bad if that is happening. it makes the motor rock back and forth, so change it before you get grindings gears</TD></TR></TABLE>
what if the gears are already grinding? does that mean the tranny's going bad?
Old Oct 27, 2008 | 05:32 PM
whereiscarmensandiego's Avatar
a mount will mek the shifter move and possibly pop out of gear&gt;?? man mines doing that and i thought it was the tranny.. if i give it lots of gas or hit the brakes hard it pops out of 2nd and 3rd
Old Oct 27, 2008 | 10:19 PM
eg2ekevin's Avatar
mine does this and pops 3rd gear....pisses me off. time for a new mount!
Old Oct 27, 2008 | 10:21 PM
slo_hatch's Avatar
Default Re: (eg2ekevin)
check all your bushings around your shifter/linkage. you might find a dried out piece of rubber. lol
Old Oct 28, 2008 | 04:27 AM
macson's Avatar
Default Re: (slo_hatch)
I used to have this happen to me. New shift linkage bushings took care of it.
Old Oct 28, 2008 | 06:02 AM
96 EX's Avatar
Default Re: (macson)
Mine also does this while I'm in second gear. Its not the normal amount of movement either its excess. Also I know for SURE my motor mounts are toast. So hopefully with the swap I'll get this fixed.
Old Oct 28, 2008 | 06:40 AM
koa's Avatar
koa
Default Re: (96 EX)
this could be a few things. motor mounts,tranny,shift linkage bent,shifter bushings bad.
Old Oct 28, 2008 | 08:50 AM
B16AGUY's Avatar
Honda motor mount bushings are junk.
I swapped in some urethane bushings and she's smoooth.
Old Oct 28, 2008 | 09:17 AM
pli's Avatar
pli
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macson &raquo;</TD></TR><TR><TD CLASS="quote">I used to have this happen to me. New shift linkage bushings took care of it.</TD></TR></TABLE>
i can understand it if the shifter was shaky and loose. but my friends issue is that, it seems like the whole thing moves, as if it was the tranny.
swizz977
21
Apr 14, 2012 07:13 AM
98civtec
Jun 7, 2009 05:20 PM
bl1tzk1213g
May 16, 2007 10:31 AM
manyakiexpi
May 17, 2006 09:56 PM
george34
Dec 9, 2005 06:52 PM
