Wapred Head
Old Oct 27, 2008 | 03:42 PM
romibi6's Avatar
Default Wapred Head
Hi Everyone,
My son has 94 integra 3 door LS B18B1 manual tranny and when we bought it it had a warped head. Took the head to a machince shop, they resurfaced it for us. Cleaned everything up and put it back together.
Problem I'm having is that idles very rough (almost like its got a dead cylinder) and is blowing white smoke.
I think I have everything lined up timing wise but any idea or help would be appreciated.
Thanks in advance!
Mike
Old Oct 27, 2008 | 03:59 PM
champLSinteg's Avatar
Default Re: Wapred Head (romibi6)
Why did the head warp in the first place? If the motor overheated to where it warped the head it might have gotten hot enough to warp the block. Its blowing white smoke because coolant is getting into the combustion chamber. Assuming you installed the *new* head gasket correctly I would check the block.
Old Oct 27, 2008 | 04:40 PM
romibi6's Avatar
Default Re: Wapred Head (champLSinteg)
it warped from over heating so you think the block is warped too?
New gasket kit installed!
Old Oct 27, 2008 | 05:33 PM
kronikSLOW's Avatar
x2 if your head is flat and the gasket installed correctly. then your block warped. a ls engine can be had for around 600 bucks and then you will have alot of spare parts for when you need them.
Old Oct 27, 2008 | 05:34 PM
hollums2k's Avatar
get the block decked is all i have to input. have a machine shop check it out because like champLS said your coolant is getting into the combustion chamber.
Old Oct 28, 2008 | 04:12 AM
romibi6's Avatar
Default Re: (hollums2k)
thanks guys! looks like i have to pull it all apart again!
Old Oct 28, 2008 | 06:30 AM
AWD Terror's Avatar
Default Re: (romibi6)
Just make sure that you torqued the head studs down properly. A friend made the same stupid mistake and had two studs finger tight.
JDMpadawan
Mar 18, 2014 12:27 PM
homoaranea
Sep 5, 2013 12:38 AM
strike1545
May 24, 2010 10:42 AM
youngkow
Dec 26, 2003 08:40 PM
