Good battery, good alternator and still dont turn on
Old Oct 27, 2008 | 02:48 PM
dianam321's Avatar
Default Good battery, good alternator and still dont turn on
Hi Guys!!!
My car has a new battery, the alternator is perfect, and theres something that still draining the battery, the car doesnt stop when is on the road, only when it stops for a long time... any solution???
Old Oct 27, 2008 | 02:57 PM
cjmurillo's Avatar
are your battery cable and terminals good?
Old Oct 27, 2008 | 03:02 PM
TheMuffinMan's Avatar
He knows where you live!
What kind of car is the first question.
Old Oct 27, 2008 | 03:05 PM
dianam321's Avatar
Default Re: (TheMuffinMan)
is a honda accord year 2000, v4, lx
dianam321's Avatar
Default Re: (cjmurillo)
yes, everything seems ok, i heard that could be the ignition.
Old Oct 27, 2008 | 03:33 PM
Ross 2.0's Avatar
In a Junkyard near you.
Any aftermarket accessories?
Old Oct 28, 2008 | 03:52 AM
jwicecold's Avatar
Need a little bit more info..
Does it click when tryin to start??
Does it turn over at all??
Do all the lights work and dash lights??
Old Oct 28, 2008 | 06:06 AM
dianam321's Avatar
Default Re: (jwicecold)
when trying to start it clicks, all the lights go on, and then nothing happen. I took the battery yesterday to replace it, but I dont think is that!
Old Oct 28, 2008 | 07:50 AM
P_Adams's Avatar
Default Re: Good battery, good alternator and still dont turn on (dianam321)
I'll answer this with the same answer I gave on your other DUPLICATE thread:
Disconnect the negative battery cable and connect an Amp Meter between the two.
If something is staying on, you will see a Amperage value.
Start pulling and reinstalling the fuses (one at a time) and observe the meter. Once you reach the circuit which is staying on, the meter value will drop to zero. That is your hint as to where to start looking.
Be aware that there are some systems that do stay alive, even with the key off.
Both the clock (and I believe the ECM) require a uninterupted power sourse, so plan accordingly. The amp draw for these components will be in the milliamp range and can be disregarded. It's so small a draw that it would take months to drain down a battery.
P
Old Oct 28, 2008 | 09:01 AM
tragicinc's Avatar
Well I'm assuming that if the lights are turning on it's not your battery unless its only got enough juice for the lights.
In accessory does the radio and everything work?
If so I doubt its the battery.
I had a similar situation with my car.
Read this forum... Let me know if it helps
In my case it was the main relay that was causing the car not to start
https://honda-tech.com/zerothread?id=2324403
Old Oct 28, 2008 | 06:41 PM
Ross 2.0's Avatar
Default Re: Good battery, good alternator and still dont turn on (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">I'll answer this with the same answer I gave on your other DUPLICATE thread:
P
Anything over 50mA is an excessive current draw.
dianam321
Oct 28, 2008 05:24 AM
disposable
Jun 26, 2008 08:02 PM
boostedjdmdc2
Jun 18, 2008 04:10 PM
budget
Jun 26, 2005 12:33 PM
slvrcivic97
Aug 28, 2003 06:57 PM
