how to remove rusted battery nut?
WD-40 isn't working and I'm stripping the nut just trying to get it to budge on the negative battery terminal .. any suggestions. Oh there is a lot of corrosion, any good solvents for that?
If it's that corroded, just grab it with a pair of visegrips - twist the thing off and replace it with a new bolt/nut.
You won't be able to reuse it anyway.
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cKoupe »</TD></TR><TR><TD CLASS="quote">Hammer on the next smallest socket. that will get it off, good luck getting it out of the socket though.</TD></TR></TABLE>
either use a socket you intend on losing or one with a lifetime warranty you dont car about cracking in half
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bseriescrxsi »</TD></TR><TR><TD CLASS="quote">
either use a socket you intend on losing or one with a lifetime warranty you dont car about cracking in half</TD></TR></TABLE>
lol....Time to look into buying some better sockets.
I have done the next size down socket & hammer procedure more times than i can remember. I have yet to split the side out of one of my sockets... : knocks on wood :
Although for something as light weight as the battery terminals. I think I would opt for P_Adams suggestion. There is no need to crash and bang on your battery if a pair of vise grips will work.
i've heard baking soda works good for cleaning the corrosion but i just use a wire brush to clean it. also auto zone sells this stuff to put on the terminals for better connection i think that would help too
