problem replacing antenna mast
Old Oct 27, 2008 | 01:29 PM
ndrew2505@yahoo.com's Avatar
Default problem replacing antenna mast
in order to get the mast in i had to take the motor assembly apart and take out the old mast b/c it broke off from the old antenna. i got the mast put in and when you first turn the key it goes up smooth but when i turn the key off and the antenna goes down it hangs up and doesnt go all the way down. any ideas on what went wrong? cars a 91 accord ex
Old Oct 27, 2008 | 01:33 PM
Ross 2.0's Avatar
In a Junkyard near you.
Have you tried lubricating it?
Old Oct 27, 2008 | 01:35 PM
Default Re: (Ross 2.0)
ill try it but all i got right now is white lithium grease. will that work ok for this?
you are talking about the mast correct? i did put some grease in the motor/mast gear compartment when i put it back together.
lancerkid06
Feb 27, 2010 08:56 PM
teg_dc2
Dec 10, 2007 11:39 AM
Lude-Conduct
Oct 19, 2003 10:22 AM
distuRbed
May 16, 2002 08:45 AM
SleepinGSR
Feb 27, 2002 02:03 PM
