cylender positon sensor on dohc zc
Old Oct 27, 2008 | 01:08 PM
driftam1's Avatar
Default cylender positon sensor on dohc zc
my ecu pm6 i throwing a code for cylender positon sensor which isnt on the dizzy and my car is running like **** what can i do to fix it ???
Old Oct 27, 2008 | 01:11 PM
sleepingciv's Avatar
Default Re: cylender positon sensor on dohc zc (driftam1)
the pm6 should still pick it up even though its not in the dizzy what dizzy ya using?
Old Oct 27, 2008 | 01:13 PM
jlicrx's Avatar
CYLinder sensor , code 9, on DOHC ZC is usually caused by incorrect camshaft timing - exhaust cam is probably off one tooth
Old Oct 27, 2008 | 01:18 PM
driftam1's Avatar
Default Re: cylender positon sensor on dohc zc (jlicrx)
i also have a code 20 e. l . d. ?? runs good off and on and somethimes it will sputter allot and how do i check if my fuel pump is good or could be going out?
Old Oct 27, 2008 | 02:42 PM
driftam1's Avatar
could this code be cause by a code 20 electical load detector?
Old Oct 27, 2008 | 02:45 PM
your cyilnder positon sensor could be going out?
Old Oct 27, 2008 | 02:59 PM
driftam1's Avatar
Default Re: cylender positon sensor on dohc zc (sleepingciv)
can you get that part at auto zone? how can i check to see if its going out i dont want the change the fuel pump
Old Oct 27, 2008 | 03:01 PM
I think you can get it from like a 89 integra, i think
sorry no idea how to test it sorry
Old Oct 27, 2008 | 03:21 PM
driftam1's Avatar
well if its throwing a code i guess its bad if the wireing good thax n also would there be a code if the fuel pump was going out? my friends was goin out in his ef and it was acting almost like mine is except mine runs good at times and bad most the time wasting too much gas i went 100 miles on half a tank dosent seem like wat it used to be
RyanJayx
Jul 6, 2009 01:42 PM
jdm91CrxSi
Apr 18, 2006 03:02 PM
sloweh3
Mar 30, 2004 06:30 PM
EF'n
Aug 20, 2002 01:11 PM
FBPninetynineEM1
Jul 26, 2002 06:32 AM
