code 4 on zc
code 4 on zc
what all could cause the crank angle sensor code to go? the timing is good and i check the wiring. this is in my 91 rt wagon that i have been driving for about a year.
Re: code 4 on zc (dohcsideSi)
the sensor is not in the dizzy, its in front of it. He doesn't need a new dizzy. Check the CAS to se if you need a new one. More than likely you will and can use it of an 88-89 integra
Re: code 4 on zc (lilrex)
wrong, code 4 is in dist.
code 9 is the one on the exh cam.
Had it and code 8. Got a 89 dist from Advanced, and it went away.
Re: code 4 on zc (Bgladfelter)
MY CHECK ENGINE LIGHT IS STILL ON FOR MY ZC
I had a Code 4 and a Code 8, but now i only have a Code 4 b/c i replaced the distributor with a used one from a local junkyard.
I'm clueless how to get ride of this Code 4........Need help guys plzz, my car runs like its STOCK! AHHHH
Re: code 4 on zc (DaREX)
do this and try it..... invert the two cables off the crank angle sensor
i had that problem and the perf shop told me i had it wired backwards.... and i did it ZC style...... make sure u dont have it that way....... thats its like the mot bitchy code u can get.. i hate them soooooo bad since i had it for months, and was cutting my rpms by half.....
Re: code 4 on zc (JDM EF9)
I tried inverting the Crank Angle Sensor wires before and that didnt help it at all. Actually it made it worse and did some weird bogging. If anyone has any advice plzzz help me..............Plzzzzzzzzz
89HTACH
22
03-20-2004 04:53 PM
