code 9
Old Mar 7, 2006 | 03:12 PM
jdm91CrxSi's Avatar
Default code 9
my ecu is throwing a code 9 and that's my #1 piston, but everything seems to be fine..
Old Mar 7, 2006 | 03:13 PM
jdm91CrxSi's Avatar
Default Re: code 9 (jdm91CrxSi)
any suggestions, running a dohc zc w/ pr4 ecu also tried pm6.. same problem
Old Mar 7, 2006 | 03:19 PM
Steri's Avatar
Saw this in another thread don't know if it helps
https://honda-tech.com/zerothread?id=468260
it has great trouble shooting flow charts.
Old Mar 7, 2006 | 03:24 PM
jdm91CrxSi's Avatar
Default Re: code 9 (89EF_Sleeper Si)
codes are diffrent for every engine, i don't think its my crank position though it should be top dead center or it wouldn't be running right.. correct
Old Mar 7, 2006 | 03:52 PM
jdm91CrxSi's Avatar
bump for the hump
Old Mar 7, 2006 | 04:06 PM
RCautoworks's Avatar
Code 9 - No. 1 Cylinder Position Sensor
It's the third sensor in the dist., and it detects the position of the No. 1 Cylinder, as the base for the Sequential Injection. It can also be located on the camshaft of DOHC engines.
CYP sensor is mounted on the exhaust cam on the ZC.
If the dist. base bearing starts failing, it will heat the sensor(s) up, destroying the magnetism thus causing a code(s). It will lose 10% of it's strenght, each time it is heated up to 170 degrees plus.
In most cases, replacing the distributor is the only alternative. Especially if the bearing has failed.
Honda does don't stock the bearing by itself, but other after-market compaines are said to have one.
If you have problems starting the engine, or drivability after the install check your cam aligment. The seizing bearing might have caused it to jump a tooth/notch or two. From the extra drag due to the bearing failing.
Old Mar 7, 2006 | 04:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi &raquo;</TD></TR><TR><TD CLASS="quote">codes are diffrent for every engine, i don't think its my crank position though it should be top dead center or it wouldn't be running right.. correct</TD></TR></TABLE>
Actually there different for every obd, but obd0, obd1, obd2 codes are the same
Old Mar 7, 2006 | 04:08 PM
jlicrx's Avatar
your camshaft timing is off one tooth or more on the exhaust cam
Old Mar 7, 2006 | 04:25 PM
jdm91CrxSi's Avatar
Default Re: code 9 (jlicrx)
na it's prbably because i have the cam sensor disabled lol thanks for the information though, the engine actually runs perfectly fine nothing to bad if so then forget it i got 2 more sexy's
Old Apr 18, 2006 | 03:02 PM
thrty8street's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">your camshaft timing is off one tooth or more on the exhaust cam</TD></TR></TABLE>
is this only for DOHC engines?
I am running an HF dizzy on a d16a6 will this cause me to throw this code?
RyanJayx
Jul 6, 2009 01:42 PM
2poor2tune
Jun 23, 2006 01:38 PM
FBPninetynineEM1
Jul 26, 2002 06:32 AM
crxgurlllll
13
Feb 12, 2002 07:11 AM
Cereal_Killer
Jan 23, 2002 04:58 AM
