A/C problem.. condensor gets insanely hot almost instantly.. compressor cuts off and on
Old Oct 27, 2008 | 11:37 AM
marcj's Avatar
Default A/C problem.. condensor gets insanely hot almost instantly.. compressor cuts off and on
so my a/c is acting up pretty bad all of the sudden.. when it's on the lines to the freon canister get almost too hot to touch, and so does the condenser.. the cold side stays cold and is covered with condensation. I started noticing a problem when the compressor would kick on and off constantly.. any ideas?
Old Oct 27, 2008 | 03:25 PM
itsmejto's Avatar
Default Re: A/C problem.. condensor gets insanely hot almost instantly.. compressor cuts off and on (marcj)
High temp/pressure in the condenser is caused by system blockage, dirty coils, to much freon, cooling fan not runing, old clogged dryer, etc etc etc, you need a set of gauges and know how to read them or take it to a shop before you blow up your compresor or coils.
Old Nov 11, 2008 | 10:48 AM
MrXclusivE's Avatar
^^ what he said.
Timbogates
Honda Civic (2006 - 2015)
Aug 20, 2018 02:33 PM
guy5978
Jul 22, 2008 11:14 AM
EG6R
Apr 11, 2007 08:40 PM
jasonrush
Jun 2, 2006 08:17 PM
LsTurbo91
Aug 5, 2002 07:05 PM
