5spd Tranny swap question
So I have an 05 Type-S and I've gotten rid of the K02Z1 for the K24A2 out of an 05 TSX. I am going to be swapping it to a 5 speed transmission. Now I have a couple of questions before I buy one. First, I know that the EP3 5speed has better gearing than the base model RSX. My question is:
Is there any year more specific I have to go than the other because the 05-06 rsx uses a different VSS. That is one of the problems with the stock 6spd trans when using K-pro. So I need to make sure I can get this swap working.
Any suggestions or help would be most appreciated. Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-’S’paz »</TD></TR><TR><TD CLASS="quote">Sorry I'm installing the JRSC with 10-12 pounds of boost. And basically the 5spd will have longer gears and be more useful than a 6spd. </TD></TR></TABLE>
Ehh, I disagree. For a turbo, yes but for a SC, you'll likely be quickier with the shorter geared 6 speed.
My thoughts exactly...If you're running an RSX ecu you can install the TSX 6th gear in the 5 speed and possibly get a different FD while achieving awesome highway mpg...was going to do it before I decided to sell my EP3
b18c1ebpsol
Mar 29, 2010 12:00 PM
