wich sparkplugs should be used on a b16 turbo ?
Hi! i wanted to know wich sparkplugs are better for a b16 turbo
T3/T04E TA3405
Now i've Denso iridium IK22 installed on it
Thanks!
T3/T04E TA3405
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">I'm not sure of your power level, but when i was running my stock block GSR at ~300whp, i was using NGK BKR7e's gapped at .28</TD></TR></TABLE>
bkr7e are good for 400 also, not sure when people switch to an 8 series though
Im pretty sure i'm running 8's with a .28gap at 416whp. Havent changed them since it was took off the dyno tho. Poor thing never gets drove
Doesn't the plug choice depend on the tune also?
I've installed an MSD Pro SS coil and MSD SCI-L ignition controller
I'm looking for the best performance, and street drivability. If that couldn't be possible, i would like to know wich're better for performance an wich for daily driving
I'm also using 950cc injectors and unleaded premium fuel
Are those plugs what're we talking about?
http://cgi.ebay.es/NGK-spark-p...l1116
I've seen somewhere that platinum/iridium plugs are not the best choice for turbocharged b16, is it true?
Thanks!
Pd: what do u think about the denso iridium IK22??
Modified by vantta at 1:19 PM 10/27/2008
Thanks!
This spark plug is resistor type?
BKR7 plugs are Platinum plugs, is this better than an iridium ones?
There's any problem with the Denso IK22? I already have 4 installed, and i want to know if the BKR7 are better (i know that they're cheaper), because if they're better i'll buy ones now haha
I've seen that BKR7 are one step colder than the stock spark plugs, also the Denso IK22 are one step colder too
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vantta »</TD></TR><TR><TD CLASS="quote">This spark plug is resistor type?
Thanks!</TD></TR></TABLE>
BKR's are convention/copper-tip/resistor type plugs, not platinum.
The iridiums tend to last longer, but on a turbo application, since maintanence is the key, you're just spinning your wheels here. a good 7 range spark plug from NGK or Denso is just fine #2975
no nee dto over think something like this
Ok!
now to sump up:
wich of those 3 plugs are the plugs wich i'm looking for?
http://cgi.ebay.com/NGK-spark-...l1177
Thanks!
now to sump up:
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord_raffi »</TD></TR><TR><TD CLASS="quote">did anyone else notice the price jumps in bkr7e's lately? i think someone was trying to sell them for 12.50 on some site...for each.</TD></TR></TABLE>
That's a rip off. They are like $2 each lmao.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">
That's a rip off. They are like $2 each lmao.</TD></TR></TABLE>
Ya i remember paying like $3 which is why i was like wtf. maybe they were being sold in packs of 4 tho...i thought they said per plug.
I'm using an AEM EMS 30-1050, MSD Pro SS ignition coil, MSD SCI-L ignition controller and MSD 8.5mm wires
The BKR7E-11 are non resistor plugs or resistor plugs? :S
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vantta »</TD></TR><TR><TD CLASS="quote">Hi! i wanted to know wich sparkplugs are better for a b16 turbo
T3/T04E TA3405
Thanks!
https://honda-tech.com/zerothread?id=2388595
I dunno if it would be different for you though...
T3/T04E TA3405
Thanks!
^^^^^^What he said^^^^^^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR »</TD></TR><TR><TD CLASS="quote">
^^^^^^What he said^^^^^^</TD></TR></TABLE>
Not tryin to threadjack but I think the OP might find this question interesting as well...
It's funny how MOST turbo guys use the BRK's but yet when I tried a new set and gapped them to .30, they made the car run like crap and when I put the Iridium IX back, it basically came to life again (could tell a big difference in acceleration, etc.) - I still wonder why this happened - maybe it has something to do with my tune???
they are resistor, if your EMS responds well to non resistor plugs i would use 4554.
I run those on ectune, never really dynoed the car but the car runs strong and people have got around 20whp and 20torque gains better idle without missfires with large injectors and so on. But you can only run those with select ems (for example you can run them on ectune but not on s300).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcguy760 »</TD></TR><TR><TD CLASS="quote">
It's funny how MOST turbo guys use the BRK's but yet when I tried a new set and gapped them to .30, they made the car run like crap and when I put the Iridium IX back, it basically came to life again (could tell a big difference in acceleration, etc.) - I still wonder why this happened - maybe it has something to do with my tune???</TD></TR></TABLE>
I would be the wrong one to ask why on that issue.
smoothludey2
Jan 7, 2002 08:00 PM
