s300 & omni power 4bar map problems
i am having a little trouble with the map sensor its omni power i swaped it out with my stock one then went in the smanger in the s300 and changed it from the stock one to the 4bar and it went fine started up and i drove it around i am driving down the road a day later and my car just dies for no reason so i new it was the map sensor cause my car had been running fine for months prior it just wouldent start the car i would wait like 30 mins and my car would start and run drive some more then it would stall took me 4hr to get home i am going to get retuned wed with it but is there anything i missed setting it up ?
That is one long sentence.I can't really tell what you asking.If your 4bar is bad,get a new one.Was it tune with the 4bar and you replaced it with a stock one?Then you changed the settings and then the stock one went bad?
if you feel there is a problem with the Omnipower MAP sensor just send it to us at the address below and we will run it through a series of tests to determine if there is a problem. If there is a problem we will send you a new one.
OmnipowerUSA
2252-B Sierra Meadows Dr.
Rocklin, Ca. 95677
We also have a phone number if you need to talk to us directly
951 956 6959
thanks steve
OmnipowerUSA
Rocklin, Ca. 95677
951 956 6959
thanks steve
well i went for a tune with the 4bar last night . it worked great the whole night untill we went to finish up the street tune. died right before we got back to shop had to swap the stock one in on the side of the road ther weird thing is it runs fine then fails after awhile
(edit it will be on the way to you guys very soon )
imbrzyant
Dec 30, 2007 07:10 PM
