Steel braided line fittings
Old Oct 26, 2008 | 02:22 PM
IntegraType-R's Avatar
Default Steel braided line fittings
I've tried summit, as i have a account with them and have come up with nothing..
I've searched just about every auto parts store in baton rouge today alone..
I'm trying to connect two of my lines together..
i'm looking for a double ended male connector. 1/8'' i believe here some pics
I'm trying to find a longer nipple as i'm not applying enough pressure to the fittings and it seems to leak in this one spot because i'm not going deep enough.
This is just an example, but in the middle connection where i'm connecting both lines it leaks a tad bit only because i dont have a long enough nipple.
i've tried lowes and ace hardware as well.
Any thoughts?
Here's a picture of the connector i have now, again its too short the way it goes into the line, going into the fitting it fits fine.
the big line u see going to the gauge is a line kit i got from summit, the other line u see is a russell, I'm just trying to fix this w/o having to buy another line kit.
Modified by IntegraType-R at 5:30 PM 10/26/2008
Old Oct 26, 2008 | 02:29 PM
Natural Aspirations's Avatar
Default Re: Steel braided line fittings (IntegraType-R)
All-Motor tech
Old Oct 26, 2008 | 02:32 PM
lude98SH's Avatar
http://www.jegs.com/p/JEGS/758529/10002/-1
I thought only AN style fittings had to bottom out to seal due to the flare style ends. NPT i was always under the impression that they were kind of an inteference fit and depending on what your using it for use either teflon or another type of sealant on it.
http://www.cutting-tool-supply...F.htm
Modified by lude98SH at 6:37 PM 10/26/2008
Old Oct 26, 2008 | 02:38 PM
DonF's Avatar
Default Re: Steel braided line fittings (lude98SH)
You need to get rid of the adaptor. You need a 6-6 or 4-4 AN connector. I cannot tell from the pic's but it should be a -6. If you need something longer get a "bulkhead" -6-6 fitting.
Old Oct 26, 2008 | 02:47 PM
lude98SH's Avatar
Default Re: Steel braided line fittings (DonF)
That would make sense since it shouldnt have to bottom out using NPT it should tighten up. And if he shows us a pic of the inside we can tell for sure if its an AN fitting.
Did the 1/8 npt go in smoothly ?
Also how deep are those threads on your female connections ?
Old Oct 26, 2008 | 03:53 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">That would make sense since it shouldnt have to bottom out using NPT it should tighten up. And if he shows us a pic of the inside we can tell for sure if its an AN fitting.
Also how deep are those threads on your female connections ? </TD></TR></TABLE> Looking at his first pic, it is an-an with some stupid adaptor that will not seat. For fuel it should be -6. If it -4 we are going to have threads on why it runs lean on the top end.
Old Oct 26, 2008 | 04:32 PM
oil pressure gauge, number 1, this isnt a fuel line i wouldn't jimmy rig that.
Secondly.. I have no idea, i bought the line from summit.. it was http://store.summitracing.com/...w=sku
, then locally from a race shop i bought the russell ine. Just trying to connect them both.
Brand: Auto Meter
Product Line: Auto Meter Tubing and Line Kits
Part Type: Gauge Supply Line Kits
Part Number: ATM-3227
Supply Line Type: Hose
Hose Size: -4 AN
Hose Length (in): 36 in.
Hose Length (ft): 3 ft.
Hose End 1: -4 AN female
Hose End 2: -4 AN female
Hose End Fitting Material: Steel
Hose End Fitting Finish: Zinc plated
Hose Material: Braided stainless steel
Hose Finish: Natural
Tubing Diameter (in): in.
Fittings Included: Yes
Quantity: Sold as a kit.
is the line from summit.
The other i got from lightning i'll figure out which tomorrow.. i'm assuming its -an to NPT tho thats my guess.
Old Oct 26, 2008 | 04:36 PM
lude98SH's Avatar
then use a -4AN union.
http://www.jegs.com/p/JEGS/752560/10002/-1
Also there is no need for teflon or any type of sealant on AN fittings.
Old Oct 26, 2008 | 04:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">then use a -4AN union.
http://www.jegs.com/p/JEGS/752560/10002/-1</TD></TR></TABLE>
-4 to -4?
Old Oct 26, 2008 | 04:38 PM
lude98SH's Avatar
yes, if both ends are -4AN then you want the same size.
Old Oct 26, 2008 | 04:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">yes, if both ends are -4AN then you want the same size. </TD></TR></TABLE>
k
Thx for the link
Old Oct 26, 2008 | 04:41 PM
lude98SH's Avatar
no problem
Old Oct 26, 2008 | 04:46 PM
k orderd , thx
Old Oct 26, 2008 | 04:53 PM
Default Re: (IntegraType-R)
problem solved / thread.
FlewByU352
Jan 5, 2012 06:13 AM
turbotime
Apr 23, 2006 08:25 PM
275Performance
Feb 11, 2004 01:06 PM
ILOVEGIRLS
Sep 16, 2002 02:08 PM
