OBD1 head and OBD2 Distibutor, what do I need to make it work?
Old Oct 25, 2008 | 03:34 PM
c1v1c98's Avatar
Default OBD1 head and OBD2 Distibutor, what do I need to make it work?
I have an OBD1 (1994) H22 head and OBD2 distributor (1997 SH).
Is the wiring/plug conversion the only thing that is need to make these 2 work together?
Will the OBD2 distributor bolt right onto the OBD1 head?
Anything else I should now about doing this?
Old Oct 25, 2008 | 05:10 PM
AndyD's Avatar
Default Re: OBD1 head and OBD2 Distibutor, what do I need to make it work? (c1v1c98)
Which ECU will you be running?
Old Oct 25, 2008 | 09:56 PM
c1v1c98's Avatar
Default Re: OBD1 head and OBD2 Distibutor, what do I need to make it work? (AndyD)
Well, basically a 97 SH ecu. I have a Type-S short block on the way to be mated with my OBD1 head. So, in the end I might end up with a Type-S ecu or something else to make it tuneable.
Old Oct 25, 2008 | 10:00 PM
vinuneuro's Avatar
No you won't have to make any wiring changes. Make sure you use a usdm oil pump because your usdm ecu will look for the ckp sensor at the pump. Fitment wise they're all the same
Old Oct 26, 2008 | 06:23 AM
c1v1c98's Avatar
Default Re: OBD1 head and OBD2 Distibutor, what do I need to make it work? (vinuneuro)
Are you sure the plugs are the same?
http://bbmoto.net/wiki/index.p...rsion
Old Oct 26, 2008 | 04:55 PM
c1v1c98's Avatar
/Bump/
Old Oct 26, 2008 | 06:31 PM
AndyD's Avatar
Ah, ok. OBDI and OBDII H22 heads are the same. You will be fine mounting the OBDII distributor to it.
Old Oct 26, 2008 | 06:41 PM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1v1c98 &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure the plugs are the same?
http://bbmoto.net/wiki/index.p...rsion</TD></TR></TABLE>
If you use the wiring harness from your car's engine you won't have to make any wiring changes.
Old Oct 26, 2008 | 06:52 PM
c1v1c98's Avatar
I was just thinking I had to use an OBD1 distributor. It all makes sense now
pat91hb
May 22, 2008 07:54 AM
wens_crx
Aug 8, 2007 07:48 AM
Adam West
May 8, 2006 03:47 AM
crxhybrid85
Mar 7, 2005 03:51 AM
hatchy
Feb 21, 2002 01:11 AM
