Distributor Question.
Old Oct 25, 2008 | 04:02 AM
My_EFsedan's Avatar
Default Distributor Question.
i have a 92 LS motor about to be swapped in a sedan. motor is obd1 and i am wiring the car to obd0 with an obd0 ls ecu. i already have everything to be swapped.
i looked up rewire and they have the obd0 to obd1 conversion harness
i mean can we reverse and do obd1 to obd0??
from Ryans site it says "To use a OBD1 Distributor, you must also be using an OBD1, OBD2a or OBD2b ECU. (OBD Compliant)"
since everything is gonna be obd0 including ecu does dizzy matter? if i just repin to obd0 plugs using this link
https://honda-tech.com/zerothread?id=1349052
better yet, is an OBD1 possible to be used with an OBD0 by de-pinning?
Old Oct 25, 2008 | 11:21 AM
My_EFsedan's Avatar
Default Re: Distributor Question. (My_EFsedan)
help...make life easier and get an obd0 ls dizzy huh?
ryanangelo212
Mar 18, 2013 12:23 AM
88EDHatch
Nov 12, 2010 11:27 AM
VegasInvasion
Jul 1, 2010 10:49 AM
crxsteve
Aug 10, 2007 03:15 PM
ludesrv
May 12, 2007 08:58 PM
