H22a OBD1 in my.............
Im getting an H22a OBD1 in my 98 Ek hatch which is OBD2 now what do i need for this swap to work correctly in my car? please give me list and sites to get those things thanks
search, but there's not much info cuz i looked cuz i want to do close to the same but maybe a f22b1 block and f22a6 head or h22 head, it will use the same mounts. hasport makes them.
That swap will go in but you'll need to get an H22 dizzy that is internal coil (most are external coil, especially OBD1's) and you'll be able to swap it in basically as a B-series, aside from the shift linkage and different mount kit. Check out these threads (From the FAQ's of this forum)
OBD-I Engine into OBD-IIa or OBD-IIb civic or integra https://honda-tech.com/zerothread?id=1972711
Basic H22 Swap Information https://honda-tech.com/zerothread?id=362984
Also you might consider H2B (B-series running gear with an H22 Motor)
H2B FAQ https://honda-tech.com/zerothread/1998426
Good Luck!
Good Luck!
