crank woodruff key slot
Old Jul 29, 2002 | 02:43 PM
brownshigh's Avatar
Default crank woodruff key slot
alright fellas,heres the problem,i recently built my 93 ls bottem end.shotpeened ls rods,arp rod bolts,usdm itr slugs,new bearings and so on.ok,i used a impact to tighten my crank pulley bolt and it was fine for about 200 miles.i go to check my crank pulley and it wiggles and rotates back and forth.now at this time i know im flucked cus i figure the crank is reamed out cus the woodruff key is missing.after futher observation,i install another woodruff key and new(almost new)crank pulley.i tighten again with the impact.100 miles later it does the same thing again .im so hurt at this time i havent even taken the pulley off yet but imma guess it looks the same as first time.what should i do.is there any way i can fix this problem.jus to clarify,the crank was new and the woodruff key slot is not reamed out to my knowledge.but if it is,is the neway i can fix this???
Old Jul 29, 2002 | 02:55 PM
that SCION girl's Avatar
Default Re: crank woodruff key slot (brownshigh)
is the bolt actually coming loose ??? Or is the crank snout worn down ??? If its just the bolt coming loose, I would suggest some blue loctite on the threads of the crank bolt & then torqueing it down to the correct specs ...
Old Jul 29, 2002 | 03:22 PM
brownshigh's Avatar
Default Re: crank woodruff key slot (allmotorgurl)
the first time the bolt came loss,this time the bolt is still tight,it doesnt wiggle nemore,but it does rotate back and forth.i did put the woodruff key in correct and i tighten everything to spec,i dunno im busted and fustrated.
Old Jul 29, 2002 | 04:49 PM
non-VTEC's Avatar
do you have the timing belt guide plates installed before you put the key and crank pulley on?
if the rear guide plate is missing the key will slide all the way to the end of the crank shaft nose and eventually fall out.......
part number 13 listed in this picture:
[Modified by non-VTEC, 8:51 PM 7/29/2002]
Old Jul 29, 2002 | 05:29 PM
brownshigh's Avatar
Default Re: crank woodruff key slot (non-VTEC)
yes,i cant understand.everything is perfect.my only guess is that the crank had a defect or something.but come to think of it,the crank is not remanufactured,its a stock,reconditioned ls crank.welp,im tired of workin on this car,and if i cant fix this problem,i will more than likely part out the motor
Old Jul 30, 2002 | 07:23 AM
brownshigh's Avatar
anymore sugestions?
Old Jul 30, 2002 | 11:05 AM
Is the crank key actually fallin out ...or is it shearing off ...what exactly is happening to the key ???
Old Jul 30, 2002 | 05:21 PM
brownshigh's Avatar
shearing off.
FO SHO
12
Jul 18, 2012 04:19 PM
KCUF_DB8
Apr 2, 2010 09:18 PM
97Prelude_SH
Nov 19, 2009 06:17 PM
grey_ghost
Mar 12, 2008 12:52 PM
Maddox
May 24, 2004 10:46 PM
