Intake Manifold
Old Oct 23, 2008 | 10:12 PM
EF-8SiR's Avatar
Default Intake Manifold
Just wondering about my options, i want to go aftermarket and am currently running a b16a. Another noob question: does this increase horsepower? such as one from skunk2 or hondata?
thanks!
Old Oct 23, 2008 | 10:14 PM
D16SiHatch's Avatar
Default Re: Intake Manifold (EF-8SiR)
it should increase hp/tq by a little bit. i don't know hard numbers but its not like anything extravagant. skunk2 pro-series are pretty dece though.
Old Oct 23, 2008 | 10:25 PM
EF-8SiR's Avatar
Default Re: Intake Manifold (D16SiHatch)
thanks! i'll look up some prices asap.
Old Oct 23, 2008 | 10:27 PM
redef90si's Avatar
never had one but from what i'm told there over rated. take off your stock one;get it hot tanked(cleaned out) and call it a day 2-5 hp for $250-300 ain't worth it imo.
Old Oct 23, 2008 | 10:36 PM
EF-8SiR's Avatar
Default Re: Intake Manifold (redef90si)
cleaned with what?
Old Oct 23, 2008 | 10:49 PM
redef90si's Avatar
hot tanked(tank they put greasy **** in to clean), it cleans all the ****(carbon) out of there cost maybe $30-50?
Old Oct 23, 2008 | 10:50 PM
EF-8SiR's Avatar
where would i get this done? something i could even do with a pressure washer? toothbrush and some solvents? hahahaha
Old Oct 23, 2008 | 10:57 PM
redef90si's Avatar
yup just take off all the sensors and throttle body etc... carb cleaner works great.this way you save $300,have a diy project and get to work on your car. post pics if you go with my idea,Matt.
Old Oct 23, 2008 | 11:03 PM
D16SiHatch's Avatar
yea you can do a pretty darn good job with just degreasers and some elbow grease. or you could paint it if you like. these are two d16 mpfi intakes i cleaned, primed, and painted. just kinda experimenting with diff colors. and i scrubbed like hell to clean that fuel rail off on the 2nd IM, but for the life of me it would not come off be sure to remove all sensors, vaccum lines, fuel rail, and tb. and then tape everything off.
i didnt feel like spending that kind of money on an intake either so i just bought a replica. sure the build quality isnt as top notch as i'm sure the skunk2 stuff is, but theres no way in my mind its worth $250-300 for such a small gain. i'd rather spend the money elsewhere. like a gsr or somethin
Modified by D16SiHatch at 3:11 AM 10/24/2008
Modified by D16SiHatch at 3:12 AM 10/24/2008
Modified by D16SiHatch at 3:16 AM 10/24/2008
Old Oct 23, 2008 | 11:07 PM
EF-8SiR's Avatar
Thanks for the pics and info!
i'll let honda-tech know how everything worked out.
Modified by EF-8SiR at 12:40 AM 10/24/2008
Old Oct 23, 2008 | 11:08 PM
redef90si's Avatar
wow those painted IM's look great; i like the gunmetal looking one a lot. DIY !
Old Oct 24, 2008 | 12:03 AM
sleepingciv's Avatar
I had bought a skunk2 for my mini me, then bought a $40.00 y8 one and i like the y8 much better then the skunk one.
Old Oct 24, 2008 | 06:26 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: Intake Manifold (sleepingciv)
Time for me to chime in on an answer to the OP. If your running a B16A, the very best intake manifold that has been dyno proven against many other aftermarket brands was beat out buy the oem 2nd gen B16 manifold, the P30.
It can actually be improved one step further by sending it out to extrude hone if you are looking to max all out performance.
stutler_jdm
May 14, 2011 09:05 PM
mortificationrock
23
Aug 28, 2007 08:18 PM
azn99si530
25
Mar 22, 2007 03:18 PM
SI BOII
Feb 19, 2007 06:23 AM
chero112
14
Sep 9, 2004 05:16 PM
