has anybody had problems with GM or AC Delco synchromesh ??
Old Oct 23, 2008 | 07:45 PM
syne's Avatar
Default has anybody had problems with GM or AC Delco synchromesh ??
i want to know if anybody with 4TH or 5TH Gen Preludes ever used Synchromesh in your transmisson ?? have you had any problems over time ? is it too thick?? is the Friction modifed any better?? wanted to use but i had some question anwsered first ..
Old Oct 25, 2008 | 12:30 PM
syne's Avatar
Default Re: has anybody had problems with GM or AC Delco synchromesh ?? (syne)
give me some feedback has anybody used this stuff? how long?
Old Oct 25, 2008 | 12:41 PM
96-h22a1's Avatar
i have no clue man and im just as interested as you are, i was going to flush my tranny fluid today but wasnt sure what to put in, i didnt know if i should only use honda or not >.>
Old Oct 25, 2008 | 12:46 PM
syne's Avatar
Default Re: has anybody had problems with GM or AC Delco synchromesh ?? (96-h22a1)
yah i wanna too but before i make a move with synchromesh i need to know what happens long term .. i herd people say its the best thing they have put in their trans .
Old Oct 25, 2008 | 01:15 PM
prion's Avatar
I used it in my old H23 transmission for a while and it helped a bit, as I had a 3rd gear grind.
But If you have not tried the new Honda MTF it is just as good as the synchromesh, I would try it before anything else. I run it now in my H22 trans and it is excellent, much better than the old honda MTF.
Old Oct 26, 2008 | 08:51 AM
slamdlude's Avatar
https://honda-tech.com/zerothread?id=1400883
Old Oct 26, 2008 | 12:45 PM
syne's Avatar
Default Re: has anybody had problems with GM or AC Delco synchromesh ?? (prion)
hey prion how long has honda had a new mtf ? is it good for synchros like synchromesh? i guess you only get it from honda?
Old Oct 27, 2008 | 06:44 AM
SKDRCR's Avatar
Some people on here use it if their synchros are going out. I used the friction
modified stuff in my old h23 trans as well for a 5th gear grind. It's basically
just a bandaid though. I wouldn't put in a perfectly good transmission though.
I just have Mobil-1 10w30 in mine but I will probably change to the
Honda MTF the next time I change it.
Old Oct 27, 2008 | 09:27 AM
syne's Avatar
Default Re: has anybody had problems with GM or AC Delco synchromesh ?? (SKDRCR)
yah a couple times it was kinda hard to get into gear from first to second once and from second to third once . somone said synchros maybe worn out a bit and they said to use it and it should fix it . no grinding tho so the problem isnt that bad . i never wanted to use this product unless i was completly sure it wouldnt over time hurt the trans .some said to use the new honda mtf . they said its as good as synchromesh not sure if this is true . thanx for the feedback
Old Oct 27, 2008 | 05:21 PM
prion's Avatar
In my experience, the newer Honda MTF is as good as the synchromesh. But then I only have a sample size of two transmissions that have seen both fluids. I currently run the Honda MTF in a transmission that has some slight syncro issues and it smoothed it out to the point where I'm happy to drive it again.
I'm going to go out and say, before you start trying different concoctions of tranny fluid, try the Honda first. It's been out a couple of years, its definitely compatible, and it may be all you need. You can always add something else later if you want to experiment. Either way, as it was said before, it's just a band-aid and will not fix anything.
Old Oct 27, 2008 | 05:27 PM
no1knows908's Avatar
No grinding here either but I'm running Shell 10w30 and every now and then it's hard to get into first from a stop. Very rarely happens if I'm rolling, but it's just really annoying having to put the extra pressure to pop it in. Sounds like a bad syncro? Would Honda MTF help out with that problem?
Old Oct 28, 2008 | 04:36 AM
prion's Avatar
Default Re: has anybody had problems with GM or AC Delco synchromesh ?? (no1knows908)
It would be an improvement over standard multiweight oil.
Old Oct 28, 2008 | 05:21 AM
VTecLude1994's Avatar
A friend of mine's EG hatch /w GSR motor and LS trans has a slight 3rd gear grind. I'll be flushing it for Synchromesh soon. I've heard good things but nothing long term.
kit50si
Sep 6, 2007 03:39 AM
Flux
25
Feb 10, 2007 08:30 PM
RagingAngel
Jun 26, 2002 08:36 PM
