Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch problem
Old Oct 23, 2008 | 10:43 AM
tasco's Avatar
Default clutch problem
i have a 92 integra ls. i replaced my clutch about 6 months ago and then all of the sudden the clutch got really hard to press down and it was hard to change gears. so i took the tranny out and the fork release spring was broke, i replaced that got it all back together and the pedal is soft and stays on the ground unless i lift it back up and when i tried to start the car in first the car would move like the pedal wasn't even pressed down. i took the tranny back out and the clutch looks to be fine. could it be the cable stretching? i have tried adjusting it all the way in both directions and tightening the cable only makes the clutch not want to disengage worse.
Creepsjr
Mar 28, 2008 08:06 AM
importdude2000
Jan 1, 2005 06:06 PM
kc90hb
14
Dec 28, 2004 10:21 PM
GooD moToRs
Jun 27, 2003 02:33 AM
tegrevboy
Oct 22, 2002 04:11 PM
