gelcoat vs. clear coat
Old Oct 23, 2008 | 07:52 AM
evokidvii's Avatar
Default gelcoat vs. clear coat
whats up guys? I have a carbon fiber hood and roof spoiler that i need to get recleared. which do you think would be the better choice, cost not an issue.
Go with a gelcoat which i think would be the best way, or just a nice Automotive clear coat?
Thank you
Old Oct 23, 2008 | 08:12 AM
trepteg's Avatar
Default Re: gelcoat vs. clear coat (evokidvii)
can you polish gel coat ? I dont know ..
personnaly , I go with the clearcoat .. you can easily polish it if you need to
Old Oct 23, 2008 | 08:31 AM
evokidvii's Avatar
Default Re: gelcoat vs. clear coat (trepteg)
you can polish a gelcoat, its what is on most boats you see
Old Oct 23, 2008 | 08:37 AM
trepteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evokidvii &raquo;</TD></TR><TR><TD CLASS="quote">you can polish a gelcoat, its what is on most boats you see</TD></TR></TABLE>
thanks for the information !
I was used to only work with clearcoat so .. I didn't know a lot about gelcoat
Old Oct 23, 2008 | 10:08 AM
evokidvii's Avatar
anyone else?
Old Oct 24, 2008 | 02:24 AM
IMPATIENT's Avatar
you need to reclear it. but you need to get a clearcoat that has u.v additive agents in it to make sure it doesnt fade again. Dupont cromaclear, dupont cromapremier, Ppg's top line brand, sikkens. basf. Most of the clearcoats that production shops use or shops that just use cheap *** material do not have the u.v additives in them and your c/f will crack and fade again later down the road. Just make sure your use a good clear with protectants. Prep it, spray 2-3 coats, let it dry for a day or two to let the c/f absorb as much material as possible to fill the pores. Than reprep and spray again. if you use a good clear like the ones i mentioned youll never have a problem with the c/f fading, yellowing or cracking again.
Old Oct 24, 2008 | 04:32 AM
evokidvii's Avatar
Default Re: gelcoat vs. clear coat (IMPATIENT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPATIENT &raquo;</TD></TR><TR><TD CLASS="quote">you need to reclear it. but you need to get a clearcoat that has u.v additive agents in it to make sure it doesnt fade again. Dupont cromaclear, dupont cromapremier, Ppg's top line brand, sikkens. basf. Most of the clearcoats that production shops use or shops that just use cheap *** material do not have the u.v additives in them and your c/f will crack and fade again later down the road. Just make sure your use a good clear with protectants. Prep it, spray 2-3 coats, let it dry for a day or two to let the c/f absorb as much material as possible to fill the pores. Than reprep and spray again. if you use a good clear like the ones i mentioned youll never have a problem with the c/f fading, yellowing or cracking again.</TD></TR></TABLE>
Thats the info i was looking for, much appreciated sir. The gel coat is wicked expensive, but i figured it would last much longer and be a little more durable that an automotive clear. But you "cleared" (Ha) things up for me.
Old Oct 24, 2008 | 07:06 PM
skellator_thoj's Avatar
you can't just shoot gelcoat over faded gelcoat and expect it to look good, its take days to wetsand the gelcoat to get it alright looking.. clearing it is the best bet..
Old Oct 25, 2008 | 07:02 AM
aristro's Avatar
Default Re: gelcoat vs. clear coat (skellator_thoj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skellator_thoj &raquo;</TD></TR><TR><TD CLASS="quote">you can't just shoot gelcoat over faded gelcoat and expect it to look good, its take days to wetsand the gelcoat to get it alright looking.. clearing it is the best bet..
This is sooo true. I had a customer try to fix his own carbon fiber bumper by re-gelcoating it. He wanted me to sand it down for him. I just lol'ed at him and declined. It would have taken probally 10 good hours and it still would not have been too smooth. Only use gel coat when you shooting it against a mold surface
Old Oct 25, 2008 | 07:23 AM
evokidvii's Avatar
Default Re: gelcoat vs. clear coat (aristro)
ok so a good clear coat it is.. thanks for the info guys, it really helped me out alot. much appreciated.
Old Nov 6, 2008 | 09:14 PM
jairobeatz's Avatar
what if u decided to listen to ur gay friend and clear coated the hood with duplicolor rattlecans. which now has oxidation under the clear coat? try buffing it out but it just doesnt work anymore? haha, seriously! should i scuff it and respray? or is my hood wasted?
Civic Hybrid
Sep 11, 2008 08:46 AM
VTEC_Du_Ma_Mai
Oct 31, 2007 09:57 PM
ProjectCD5
Sep 24, 2006 08:22 PM
The Civic Project
Aug 13, 2004 04:57 PM
black2001ITR
Mar 28, 2004 09:17 AM
