another intake question
can anyone tell me the difference between these two intakes besides the fact that they're made out of different material and the style is different?
according to the description, the second intake clears all A/C and ABS lines. so does that mean the first one doesnt?
they both clear a/c and p/s lines just a matter of preference.....i think the one on the bottom is sexy but its all up to you.....oh and also you might want to check how close it will be to the valve cover because of the heat it the cover puts off
i think its just one is made for a b16 and the other was made for a gsr. i dont think they would be interchangable since the gsr tb sits lower. i dont know for sure though.
If you look at them closely, the one on top curves more towards the fender so it would probably draw in colder air than the one below. The one below would probably draw in warmer air cuz it's closer to the engine.
they are both the same ****.the bottom one is made for a gsr intake manifold becasue it sits lower than itr,ctr,and b16.the top one is just the normal intake you would get for a itr,ctr,and b16 manifold.same performance and same price i think.
93grayeg
11
Feb 27, 2012 09:28 PM
