what and where is IACV ?
back of the intake manifold (big aluminum thing that hangs off the back of the engine). Should be 2 bolts holding it on. It has 2 rubber hoses (coolant) running into it and 1 sensor plug.
It automatically adjusts idle based on coolant temperature. It has a valve inside that opens and closes to raise idle when the engine is cold and lower idle when the engine is warm.
xpdude
May 15, 2010 04:43 PM
