Need help with edelbrock turbo compressor outlet
Old Oct 22, 2008 | 11:41 PM
1badteg's Avatar
Default Need help with edelbrock turbo compressor outlet
I have broke two of these now because of edelbrocks poor engineering. the compressor outlet hangs below the front cross member by a good 3 inches. so everytime i hit a bump, it hits and breaks. anyone else have this problem with this kit? my car is not slammed. maybe 2 inches lower than stock. im trying to find out the easiest way to fix this problem. i can weld up a new pipe thats not made from cast aluminum like the stock but stainless. any ideas on methods of fixing this? thanks. here is a link of what it looks like.
http://www.jegs.com/i/Edelbrock/350/15026/10002/-1
Old Oct 23, 2008 | 09:53 AM
wpgredteg's Avatar
Default Re: Need help with edelbrock turbo compressor outlet (1badteg)
you can cut the elbow short and use a 90* coupler elbow instead
Old Oct 23, 2008 | 01:10 PM
1badteg's Avatar
Default Re: Need help with edelbrock turbo compressor outlet (wpgredteg)
i was thinking that but the flange is the only thing that breaks each time. the rest of it is good.
Old Oct 28, 2008 | 06:59 PM
1badteg's Avatar
for those that find this thread when you have the same problem i found a fix. i kept the stock elbow that kept breaking and hacked it off midway (kept the lower half), then i made a flange for the outlet and opened up the flanges center to 1.5" and inserted an exhaust adapter in it and welded it in place. http://www.hyperformanceauto.c...0.jpg then connected the two with hose clamps and now i have a flex pipe for those damn rain gutters in front of your driveway! cheers
97Alex
Welding / Fabrication
12
Dec 17, 2007 07:46 PM
greasemonkee
Apr 8, 2007 11:25 AM
f22builder
Oct 23, 2006 07:45 PM
hyrevEF
Feb 2, 2005 11:11 PM
ChillOutWayne
May 14, 2004 08:45 AM
