Suspension & Brakes Theory, alignment, spring rates....
I want to upgrade my rear integra 2000 to 10.2
Old Oct 22, 2008 | 09:34 PM
Dark19Acura's Avatar
Default I want to upgrade my rear brake integra 2000 to 10.2
i have past 1 week to look all around to find and see how to do this upgrade
i have ear manything about the upgrade soo i never see the how to
* first kit
ep3 caliper 2002-2005
ep3 disc brake
dunno for the handbrake suposed to be Ok but need to ajust the scew because the cable come to long
witch pad use
* Second kit
DC5 RSX-S caliper
ep3 disc brake
dunno again for the handbrake
witch pad use
* third kit
DC2 ITR caliper
ep3 disc brake
witch pad use
who can tell me what is better to do and how what i need to costum i have donne the front with ITR CALIPER AND PRELUDE DISC and i have grind the bracket to fit the pad!!
soo thank you for the comment
Old Oct 23, 2008 | 03:07 PM
4DRmafia's Avatar
I heard the Ep with a 4 lug will work and the caliper bolt right up? Someone correct me if I'm wrong.
Old Oct 23, 2008 | 08:10 PM
roastbeefrichie's Avatar
Default Re: I want to upgrade my rear brake integra 2000 to 10.2 (Dark19Acura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark19Acura &raquo;</TD></TR><TR><TD CLASS="quote">i have past 1 week to look all around to find and see how to do this upgrade
check out these links
https://honda-tech.com/zerothread?id=1110005
https://honda-tech.com/zerothread?id=1090780
the ep3 si & all rsx share the same rear calipers (stamped 9 C L P 1 4 S), same sized pad and rotors, the part numbers might be different but the parts are interchangeable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRmafia &raquo;</TD></TR><TR><TD CLASS="quote">I heard the Ep with a 4 lug will work and the caliper bolt right up?</TD></TR></TABLE>
the 02-03 si rear rotors are 4X100. you can use rotors from 04-05 si & 02-06 rsx, but since they're 5-lug, so you'll have to get them re-drilled
the caliper brackets (stamped 3 E P) will bolt right on. when installing the caliper bodies, left-side goes right & right-side goes left. the calipers must be bled with the assemblies off the car since they upside down.
https://honda-tech.com/zerothread?id=1513752
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Old Oct 24, 2008 | 12:40 PM
i can use rsx-S caliper with ep3 4x100 rotor? and for the hand brake what it need to be done?
thankx for the picture and all the rest
Old Oct 26, 2008 | 07:00 AM
Default Re: (Dark19Acura)
TT-LP
Old Oct 26, 2008 | 10:17 AM
mrlegoman's Avatar
sorta OT, but when I up my rear's I just used a Fast Brakes kit. Kept the OEM GSR calipers.
Old Oct 26, 2008 | 12:28 PM
http://fastbrakes.com/shop/pro...id=81
good stuff but i want to stay with the good proportion 10.2 at the rear its the best way to go
Old Oct 28, 2008 | 10:02 AM
what rotor and brake pad i need if i buy rsx S caliper to stay 4x100?
ep3 disk with ep3 pad? or ep3 disk with rsx s pas?
Old Oct 28, 2008 | 12:24 PM
FIGARILA's Avatar
you use the pad that goes with caliper. If you want to stay 4 x 100 then use ep3 rear discs. As for the e-brake cable issue, if you us ITR rear calipers you shouldn't have any problems. Using rear RSX calipers i noticed that you might be able to just connect the e-brake cable but the bleeder nipple ends being upside down. I can post pics of the rear RSX calipers if needed.
Old Oct 28, 2008 | 12:35 PM
<U>PARTS LIST</U>
EP3 or RSX rear calipers ( stamped 9CLP14S )
EP3 or RSX brake pads
02-03 EP3 Civic Si 4X100 rear 10.2" rotor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark19Acura &raquo;</TD></TR><TR><TD CLASS="quote">what rotor and brake pad i need if i buy rsx S caliper to stay 4x100?
ep3 disk with ep3 pad? or ep3 disk with rsx s pas? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark19Acura &raquo;</TD></TR><TR><TD CLASS="quote">i can use rsx-S caliper with ep3 4x100 rotor?</TD></TR></TABLE>
yes you can...the rsx & ep3 rear calipers are the same calipers and use the same brake pads
the 02-03 ep3 civic si rear 10.2" rotor is 4X100
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airbag Club &raquo;</TD></TR><TR><TD CLASS="quote">the RSX/ep3 calipers will bolt right on with swapping ebrake mechanisms with the integra calipers. However, due to the ebrake mechanism placement, you have to put the right caliper on the left and the left on the right. Doing this will cause the bleeder valve to be upside down. So, before I mounted the caliper, I held it right side up, stuck a block of wood in front of the piston and bled the brakes. Then I turned the piston back in and mounted the caliper. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark19Acura &raquo;</TD></TR><TR><TD CLASS="quote">thankx for the picture and all the rest</TD></TR></TABLE>
reading owns joo
Old Oct 28, 2008 | 06:59 PM
thank you now i can buy all parts sooo for the handbrake what it need to be done?
Old Oct 29, 2008 | 07:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark19Acura &raquo;</TD></TR><TR><TD CLASS="quote">sooo for the handbrake what it need to be done?</TD></TR></TABLE>
let me shed some light on this...
to use RSX or EP3 rear calipers on your integra,
use the e-brake attachment lever (from your integra rear calipers, stamped 7CLP13S)
(#23 & #33 on the pic below)
swap them on to your rsx or ep3 rear calipers
and use your integra e-brake cables
http://www.slhondaparts.com/
Old Oct 29, 2008 | 08:49 AM
NICE its clear for me now!! i thi its a good post wth all detail need forthis upgrade !! thank everyone!!
Old Oct 29, 2008 | 09:29 AM
Old Oct 29, 2008 | 10:05 AM
BrakeExpert's Avatar
Default Re: I want to upgrade my rear brake integra 2000 to 10.2 (roastbeefrichie)
Hey thats my cheese man. Richie, what'd I tell you about posting pictures of my cheese man? Thats's my good *** cheese man. I miss that good *** cheese.
Old Oct 29, 2008 | 10:19 AM
Default Re: I want to upgrade my rear brake integra 2000 to 10.2 (BrakeExpert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert &raquo;</TD></TR><TR><TD CLASS="quote">Hey thats my cheese man. Richie, what'd I tell you about posting pictures of my cheese man? Thats's my good *** cheese man. I miss that good *** cheese.</TD></TR></TABLE>
rofl
Old Nov 8, 2008 | 09:34 AM
dutchman5's Avatar
Also u would need to change #25 and 35 to your integra bracket...rsx and ep3 wont fit with brake cable
Old Nov 22, 2008 | 08:09 AM
i got a problem now i have find rear caliper RSX- RRRRRR do you know if it will fit like RSX-S
Old Nov 22, 2008 | 05:12 PM
i need a fast answer or i will miss the deal!!
Old Nov 23, 2008 | 02:13 PM
tt-lp
Old Nov 24, 2008 | 03:17 PM
ttt
Old Nov 24, 2008 | 06:42 PM
DSF's Avatar
DSF
From the post right above in this very thread...
And from the link in the same post...
https://honda-tech.com/forums/acura-integra-6/ep3-dc5-10-2-rear-disc-brake-upgrade-94-01-integras-1110005/
Originally Posted by Mt3c
Complete rear calipers from rsx, rsx-s, or 02-05 civic si
-DSF
Old Nov 24, 2008 | 08:01 PM
sooo the DC5-R are different to some point! thank you i have already read this thread soo i will contact the seller to know if its writed 9 C L P 1 4 S
Old Nov 24, 2008 | 09:03 PM
i think no body have the info on the RSX-R REAR CALIPER i think also i will search moore hard to find normal rsx caliper
Cargame
Suspension & Brakes
11
Jun 25, 2024 04:26 AM
tmeracz
Apr 26, 2006 06:35 PM
siffredi
Nov 7, 2005 12:49 PM
KamikazeSol
Jul 22, 2003 07:29 AM
KamikazeSol
22
Jun 20, 2003 02:33 PM
