cf trunk problems flies open hard and fast
Old Oct 22, 2008 | 05:49 PM
si90rex's Avatar
Default cf trunk problems flies open hard and fast
got my new hood, trunk and lip today....everything is great but the trunk is so light that it flies open way too fast and hard! Is it possible to weaken the rods the act as the spring for the trunk? it opens and flies back so hard i'm scared it might break the trunk. so is the body guy that is painting and aligning everything, he pointed it out.
thanks for any help
Old Oct 22, 2008 | 05:55 PM
Historyg's Avatar
i have no tech to add, but thats just funny, just open the trunk with your key if it flys open when you hit the button from the inside. i hope someone can help
Old Oct 22, 2008 | 05:57 PM
eg_boi's Avatar
Default Re: (Historyg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Historyg &raquo;</TD></TR><TR><TD CLASS="quote">i have no tech to add, but thats just funny, just open the trunk with your key if it flys open when you hit the button from the inside. i hope someone can help</TD></TR></TABLE>
x2 open with key or tie something with enuff weight to keep it from flying up when u pop the trunk
Old Oct 22, 2008 | 06:04 PM
Mrmatt3465's Avatar
Default Re: (eg_boi)
You have 2 trunk springs that pull your trunk up. I would try taking ONE trunk spring off, or look up the DIY on getting gas shocks for it. I need to get gas shocks for mine. After someone lil ***** decided to throw an enormous rock at my trunk and dent it, I picked up a new trunk with a factory spoiler. Now my trunk doesn't open at all because I do not have the "heavy duty" trunk springs. &gt;&lt;
ek99si's Avatar
Default Re: cf trunk problems flies open hard and fast (si90rex)
How about fabricating these to work for the trunk
Old Oct 22, 2008 | 06:21 PM
instructor74's Avatar
Default Re: cf trunk problems flies open hard and fast (ek99si)
I have seen people heat the lift springs to take some spring pressure away
Old Oct 22, 2008 | 06:23 PM
Mrmatt3465's Avatar
Default Re: cf trunk problems flies open hard and fast (instructor74)
http://www.civicforums.com/for....html
Thats how you fab em x]
Old Oct 22, 2008 | 07:31 PM
Frickr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">I have seen people heat the lift springs to take some spring pressure away </TD></TR></TABLE>
x2 seen this done on speed channel for the same problem as op stated.
Old Oct 22, 2008 | 09:02 PM
2000siturboR's Avatar
yea i had same problem with mine what i did with mine was just take the one rod spring out. the only problem with that tho the trunk does like to stay up. but in my eyes its better than having it fly open and possibly having it crack.
Old Oct 23, 2008 | 01:04 PM
si90rex's Avatar
Default Re: cf trunk problems flies open hard and fast (2000siturboR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_boi &raquo;</TD></TR><TR><TD CLASS="quote">
x2 open with key or tie something with enuff weight to keep it from flying up when u pop the trunk</TD></TR></TABLE>
hmmm ok don't ever say somthing like that again.. one adding weights doesn't make since, its a carbon fiber trunk for a reason.
the reason a posted was so i don't have to think twice b4 i open the trunk. accidents happen and i don't want to 4get and brake a 600 dollar trunk.
Thanks for the help everyone else
Old Oct 23, 2008 | 01:13 PM
sintype's Avatar
ha, carbon fiber trunk.
Old Oct 23, 2008 | 02:19 PM
itsmejto's Avatar
double stick tape and 4 bricks should do the trick.
norcal450
Honda Civic (2006 - 2015)
12
May 2, 2007 09:53 AM
00ekcoupe
Mar 6, 2006 06:39 PM
fujii13
Mar 3, 2005 11:53 AM
vg7z
18
Feb 24, 2005 09:10 PM
Denny
Sep 5, 2003 02:19 PM
