distributor ?
Old Oct 22, 2008 | 03:03 PM
xft's Avatar
xft
Default distributor ?
can i use a 97 EX distributor in a GSR so that i dont have to buy a new one since mine is obd1 or does it have to be a gsr
Old Oct 22, 2008 | 03:07 PM
iamthefollower's Avatar
Default Re: distributor ? (xft)
you have to use an b series vtec distributor for ur gsr. is ur motor in ur 97 ex?? or what?
Old Oct 22, 2008 | 05:10 PM
xft's Avatar
xft
Default Re: distributor ? (iamthefollower)
ya its goin into a 97 ex so im tryin to get the obd2 this takin care of
Old Oct 22, 2008 | 05:46 PM
94EG8's Avatar
Seagull Management
If you have the OBD1 GS-R distributor as well you can take both apart and just swap the CYP/CKP/TDC sensors.
Old Oct 22, 2008 | 06:17 PM
Default Re: distributor ? (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">If you have the OBD1 GS-R distributor as well you can take both apart and just swap the CYP/CKP/TDC sensors.</TD></TR></TABLE>
If he puts the gsr internals into the Ex distributor it won't bolt up to his motor, and then he still has to worry about the plugs on the obd1 distributor and obd2 harness not hooking up ..... you could take and re pin ur gsr distributor and put ur obd2 plugs on it.
Old Oct 22, 2008 | 06:19 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower &raquo;</TD></TR><TR><TD CLASS="quote">If he puts the gsr internals into the Ex distributor it won't bolt up to his motor, and then he still has to worry about the plugs on the obd1 distributor and obd2 harness not hooking up ..... you could take and re pin ur gsr distributor and put ur obd2 plugs on it.</TD></TR></TABLE>
Thats not what I meant. I meant take the OBD2 EX CYP/CKP/TDC sensors and swap them into the OBD1 GS-R distributor case. I've done the reverse before, It works fine.
Old Oct 22, 2008 | 06:21 PM
yeah but the plugs on the Gsr distributor still won't plug into his engine harness, considering the gsr distributor is obd1 and his engine harness is obd2
Old Oct 22, 2008 | 06:23 PM
unless ur talking about taking out everything and swapping it into the gsr case, I'm sorry i misread what was typed ... ur correct ..
Old Oct 22, 2008 | 06:24 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower &raquo;</TD></TR><TR><TD CLASS="quote">yeah but the plugs on the Gsr distributor still won't plug into his engine harness, considering the gsr distributor is obd1 and his engine harness is obd2</TD></TR></TABLE>
Thats why I told him to swap the CYP/CKP/TDC sensors. You know the ones those plugs are attached to. Depining doesn't work either, i've tried, the pins are just slightly different and they wont snap into the plug shell.
Old Oct 22, 2008 | 06:25 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower &raquo;</TD></TR><TR><TD CLASS="quote">unless ur talking about taking out everything and swapping it into the gsr case, I'm sorry i misread what was typed ... ur correct ..</TD></TR></TABLE>
Yup
Old Oct 22, 2008 | 06:26 PM
that sucks man, i've repinned an obd1 distributor to work on a obd0 motor, havn't really messed with the obd2 stuff.. Sorry again though .
Old Oct 22, 2008 | 07:04 PM
Hey man, if you do that with the distributor... what would you take for the gsr internals after taking them out??? I am currently needing a few things to finish build my distributor.
Old Oct 23, 2008 | 06:23 AM
xft's Avatar
xft
i donno i might even just buy a new one but the OBD1 one i have is bran new less than 500 miles on it and paid 190 for it
Old Oct 23, 2008 | 06:39 AM
B16aCRXSi's Avatar
just get a dizzy jumper harness, 30 bucks and you aint gotta do nuttin but snap it in
they have both obd1 dizzy to obd2 harness or vise versa
http://passwordjdm.com/Passwor....aspx
Old Oct 23, 2008 | 06:58 AM
xft's Avatar
xft
Default Re: distributor ? (B16aCRXSi)
ok cool man thanx alot. im kinda new on the hole honda sceen when it comes down to motor swaps
Old Oct 23, 2008 | 07:08 AM
B16aCRXSi's Avatar
no prob dude
Old Oct 23, 2008 | 07:12 AM
xft's Avatar
xft
do u no where i can get a new or uncut civic ex engine wiring harness cuz the one that came in my shell is hacked to ****
Death_to_Thieves
May 12, 2009 03:03 PM
MonsterB20Ek
Nov 1, 2007 10:58 AM
civicb16eg
Jan 7, 2007 08:58 AM
poorman's type-r
Jul 11, 2006 01:47 PM
98JDM_Type_R
Aug 20, 2004 04:42 PM
