OVERHEATING PROBLEMS NEED HALP ASAP!!
IM TRYING TO GET SOME HELP. MY CAR IS OVERHEATING AND I DONT KNOW WHY!!!!
Modified by hondakrazy at 8:52 AM 10/22/2008
Modified by hondakrazy at 9:35 AM 10/22/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveharrmr23 »</TD></TR><TR><TD CLASS="quote">have you checked your radiator fluid levels</TD></TR></TABLE>
YEA ITS TOPPED OFF.
YEA ITS TOPPED OFF.
ok did you top it off or it was there if it was there then when the motor is running do your houses have pressure or is one soft if so which one
how many miles are on the motor also are the nice miles or hard miles if you are not seeing a puddle then odds are it is the head gasket as well but the general rule is if you start to blast the heat and it cools back down the thermostat is bad but bad thermostat does not explain missing coolent it only explains half problem head gasket explains the other half that is unless you are letting puddles on the ground
ok so i took out the thermostat. it looked like crap....lol. so i replaced it an the problem is gone. thanx alot to all who helped.
skiracer8148
18
May 14, 2019 06:22 PM
Ser1N
Oct 30, 2008 11:54 AM
TheTealHatch
29
Jul 4, 2007 02:22 AM
