OVERHEATING PROBLEMS NEED HALP ASAP!!
Old Oct 22, 2008 | 07:47 AM
hondakrazy's Avatar
Default OVERHEATING PROBLEMS NEED HELP ASAP!!
IM TRYING TO GET SOME HELP. MY CAR IS OVERHEATING AND I DONT KNOW WHY!!!!
Modified by hondakrazy at 8:52 AM 10/22/2008
Modified by hondakrazy at 9:35 AM 10/22/2008
Old Oct 22, 2008 | 07:55 AM
steveharrmr23's Avatar
Default Re: OVERHEATING PROBLEMS NEED HELP ASAP!! (hondakrazy)
have you checked your radiator fluid levels
Old Oct 22, 2008 | 07:56 AM
hondakrazy's Avatar
Default Re: OVERHEATING PROBLEMS NEED HELP ASAP!! (steveharrmr23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveharrmr23 &raquo;</TD></TR><TR><TD CLASS="quote">have you checked your radiator fluid levels</TD></TR></TABLE>
YEA ITS TOPPED OFF.
Old Oct 22, 2008 | 08:00 AM
ok did you top it off or it was there if it was there then when the motor is running do your houses have pressure or is one soft if so which one
Old Oct 22, 2008 | 08:03 AM
hondakrazy's Avatar
i topped it off this morning. yes, the hoses have pressure.
Old Oct 22, 2008 | 08:06 AM
has it overheated since topping it off
Old Oct 22, 2008 | 08:07 AM
hondakrazy's Avatar
when the car is on only the top hose seems to have pressure
hondakrazy's Avatar
yea it overheats while driving but when i stop it cools off
Old Oct 22, 2008 | 08:09 AM
oh hell that sounds like your thermostat have you tried blasting the hell out of the heat when it starts to get hot
Old Oct 22, 2008 | 08:11 AM
hondakrazy's Avatar
yea and it cools right off....
Old Oct 22, 2008 | 08:13 AM
yeah it is the thermostat no big deal it is like 12 dollars at just about any parts store and is easy to replace
Old Oct 22, 2008 | 08:14 AM
hondakrazy's Avatar
ok ima try that....thanx alot bro....
Old Oct 22, 2008 | 08:18 AM
yupe good luck
Old Oct 22, 2008 | 08:22 AM
hondakrazy's Avatar
i guess i was wrong i took of the hose and the thermostat seemds to be good.
Old Oct 22, 2008 | 08:23 AM
hondakrazy's Avatar
at least i think so. i squeezed the other hose an coolant started comming out where the thermostat is
Old Oct 22, 2008 | 09:25 AM
pull it out and see if you can move that one piece inside the thermostat
Old Oct 22, 2008 | 09:30 AM
how many miles are on the motor also are the nice miles or hard miles if you are not seeing a puddle then odds are it is the head gasket as well but the general rule is if you start to blast the heat and it cools back down the thermostat is bad but bad thermostat does not explain missing coolent it only explains half problem head gasket explains the other half that is unless you are letting puddles on the ground
Old Oct 22, 2008 | 09:53 AM
hondakrazy's Avatar
ok so i took out the thermostat. it looked like crap....lol. so i replaced it an the problem is gone. thanx alot to all who helped.
Old Oct 22, 2008 | 02:07 PM
bertoDC4's Avatar
good....lol np
Old Apr 1, 2009 | 01:06 PM
sam355's Avatar
Default Re: OVERHEATING PROBLEMS NEED HALP ASAP!!
I may have to check my thermostat to fix this similar issue .
Old Apr 1, 2009 | 08:11 PM
jdmjoka's Avatar
DB squad #282
thermo or head gasket
skiracer8148
18
May 14, 2019 06:22 PM
Ser1N
Oct 30, 2008 11:54 AM
TheTealHatch
29
Jul 4, 2007 02:22 AM
Chuethou_b18c5
May 8, 2006 06:17 PM
accord2fix
Jul 18, 2003 01:32 PM
