need help asap!!!!!!
i was drivivng home yesterday night and i felt that my clutch felt really soft. also it grabs really low. another thing is my car seem to overheat. i think i have a blown head gasket. please help!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondakrazy »</TD></TR><TR><TD CLASS="quote">my exhaust has oil coming out of it i heard that usually means a blown head gasket.... correct me if im wrong. </TD></TR></TABLE>
How does it have oil coming out? Liquid out the tail pipe? Burning it?
Good warning signs:
1) Oil will be floating on top of anti-freeze.
2) Your oil will be milky.
3) You may see leaks between the head and block.
4) You car will smoke white.
5) You car will overheat, but when your rev your engine the temp will go down.
Good warning signs:
when i rev up i put my hand in front of the exhaust and my hand has oil particles. i only smoke when idling. but its very minimal. the car overheats when it sits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondakrazy »</TD></TR><TR><TD CLASS="quote">when i rev up i put my hand in front of the exhaust and my hand has oil particles. i only smoke when idling. but its very minimal. the car overheats when it sits. </TD></TR></TABLE>
Next time it overheats, rev it up and see if it does down.
What color smoke?
What color smoke?
alright so i took it for a drive and it overheated again. as soon as i turn on the heater the car cools off. when i idle the car seems to cool off. but as soon as i give it gas it heats up again.....
Thermostat...head gasket, fan, the list goes on and on...last one I had like this was a thermostat sticking. As for the clutch...many clutch master cylinders leak inside of the car near the clutch pedal of course. Look up in there with a flashlight, and see if anyhting appears to have been leaking where the rod goes through the firewall. Typical honda issue. Good luck!
yea well it ended up being just a thermostat thank god. i replace it and everything is working fine, no overheating....thanx for all the help!
Good luck!
