1 quart over on oil?
Old 09-27-2007, 04:25 PM
AccordOn18z's Avatar
Default 1 quart over on oil?
would it make it smoke?
Old 09-27-2007, 04:30 PM
OG Tech
EGfosho's Avatar
Default Re: 1 quart over on oil? (AccordOn18z)
If u are over, just go under your car and drain some oil out. problem solve. You can blow out a head gasket by putting too much oil in the engine. You can tell if the head gasket went bad if you see white smoke coming out of car and there is oil leaks all over ur block.
Old 09-27-2007, 04:32 PM
Default Re: 1 quart over on oil? (EGfosho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGfosho &raquo;</TD></TR><TR><TD CLASS="quote">If u are over, just go under your car and drain some oil out. problem solve. You can blow out a head gasket by putting too much oil in the engine. You can tell if the head gasket went bad if you see white smoke coming out of car and there is oil leaks all over ur block.</TD></TR></TABLE>
the car is smoking a minimal very tiny bit...noone would notice driving but i notice when im in it. ive only driven the car 10 or 12 miles with it 1 quart over. i know how to drain oil but would it make it smoke.
Old 09-27-2007, 04:33 PM
stock_honda_coupe's Avatar
Does it smoke? Put the oil back at the level its supposed to be at. If you have no problems now, you won't have any after you fix the problem.
Old 09-27-2007, 04:36 PM
Default Re: 1 quart over on oil? (stock_honda_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Does it smoke? Put the oil back at the level its supposed to be at. If you have no problems now, you won't have any after you fix the problem.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordOn18z &raquo;</TD></TR><TR><TD CLASS="quote">
the car is smoking a minimal very tiny bit...noone would notice driving but i notice when im in it. ive only driven the car 10 or 12 miles with it 1 quart over. i know how to drain oil but would it make it smoke.</TD></TR></TABLE>
Old 09-27-2007, 04:54 PM
Jwolf's Avatar
why does it matter if it would make it smoke? just fix the freakin thing, then if it smokes, you know that wasnt it!
Old 09-27-2007, 05:59 PM
We posted at the same time, I didn't see your post. Just fix the oil level and see if it still smokes.
Old 09-27-2007, 07:15 PM
mortificationrock's Avatar
Hell yeah it will ! it will smoke blueish smoke! Happened to stupid *** me once when i just added oil and didnt check the level.Just drain it dude
Old 09-27-2007, 07:18 PM
luvmihatch's Avatar
Default Re: 1 quart over on oil? (mortificationrock)
bro stupid ? to ask seriously jsut drain the oil out and save ur self a potentail amount of trouble..
DRAIN THE OIL TO THE LITTLE MARK ON THE STICK AND PROBLEM SOLVED
chatman_55
05-20-2009 01:16 PM
Fat Chick Magnet
01-01-2008 11:59 AM
ericstambaugh07
06-25-2007 09:08 AM
G3gsr
05-20-2003 06:17 PM
Quick Reply: 1 quart over on oil?
