accord motor mounts
Old Oct 21, 2008 | 10:04 PM
accord_raffi's Avatar
Default accord motor mounts
I've been looking everywhere and do you guys know what company makes some strong motor mounts for cd5's? Explicit Street Performance says their's are OEM replacement and i don't think HASport even makes them for the cd5. I did find polyurethane mount inserts on tasauto tho...
Old Oct 22, 2008 | 07:46 AM
Default Re: accord motor mounts (accord_raffi)
anyone?
Old Oct 22, 2008 | 09:42 AM
twkdCD595's Avatar
you can get urethane inserts for the front and rear mounts, side mounts you could use 3m window weld and fill them.
I dont know of anyone who many a direct replacement aftermarket mount like hasport or anything nice... wish i did. I would buy them in a heartbeat.
Old Oct 22, 2008 | 10:43 AM
Default Re: accord motor mounts (twkdCD595)
i thought there were a insert for the side mounts too. do you know of any specific company that makes a good insert?
Old Oct 22, 2008 | 10:51 AM
twkdCD595's Avatar
prothane or energy.
I think energy only makes a front but prothane makes a front/ rear insert for the 94-97 manual transmission cars.
dont know about side inserts never seen any, thats why i suggested 3m window weld to fill them yourself with urethane.
Old Oct 23, 2008 | 07:59 AM
my car is turboed now at 6psi. it will be at 10psi in like a month so do you think i should get the two sides and rear mounts from Explicit Speed Performance and an insert for the rear? id do the front but i had to cut the front mount to fit the turbo like all accords do with turbo installs, unfortunately. the esp ones are only oem like i said before, but they should handle the power fine since they're brand spanking new right?
Old Oct 23, 2008 | 09:46 AM
twkdCD595's Avatar
depending on how you beat on the new stock mounts they will hold up pretty well for a while. hard launches and whatnot that cause alot of engine movement/ flexing will eventually tear them up.
btw not all turbo accords loose the front mount... I still have mine (although I am not a kit, my setup is mostly fab'd from scratch).
Old Oct 23, 2008 | 11:01 AM
mine isn't a kit either. i pieced together my parts, but i didn't make my own manifold or anything. I still have part of the front mount. I just used a cutting to notch out enough for the compressor to fit. Idk why some ppl take tho whole thing out, but i figured having as much of that mount was a much better idea than not having one at all haha.
Old Oct 24, 2008 | 08:59 AM
twkdCD595's Avatar
oh and as a side note I forgot to mention... that rear prothane mount will only work on the lx/dx rear mount so if your as ex then you either have to swap the rear bracket and mount or fill it with 3m window weld as well.
Old Oct 24, 2008 | 08:27 PM
i've got the LX so i lucked out there haha.
Old Oct 24, 2008 | 10:49 PM
FastechAccord's Avatar
Try contacting innovative mounts. They carry some kits that they do not list on their website. I used their mounts in my accord for the H22 install, and I am very happy with the quality.
Old Oct 25, 2008 | 06:34 AM
Default Re: accord motor mounts (FastechAccord)
alright i'll give them a try
GK2
Jul 13, 2023 12:00 PM
tyrel-gsrturbo
Oct 20, 2012 09:46 AM
CRX MASE
Aug 29, 2009 08:54 PM
Kaspk
17
Jan 19, 2008 06:54 PM
scabbs
Sep 17, 2007 09:57 AM
