dumb questions need anwered too!
Old Oct 21, 2008 | 09:52 PM
92egcivicls's Avatar
Default dumb questions need answered too!
i have a 92 eg with a b18b1 and i need to order some misc. stuff from the local auto parts store,like a valve cover gasket,throttle body gasket,etc.
what year and vechille do i tell them i have for motor parts?
i attached a pic of my motor,its is obd2 iteslf,right? i mean the motor.
and for the valve cover do i use like permatex or some other sealent with the gaskett? or
do install it "dry"?
also the motor is stamper H M does that mean its jdm?or do usdm have them as well? or all b18b's usdm?
thanks for the help in advance!!!!!!
Old Oct 21, 2008 | 09:59 PM
slo_hatch's Avatar
Default Re: dumb questions need answered too! (92egcivicls)
for motor parts tell them the type of car the motor came out of. for example..a civic wth a ls swap out of an integra and you want a valve cover gasket...tell them an acura integra and whatever year your motor is...if it is obd2...just say like 98. simple enough.
and i never put anything on the valve cover gasket...of course i have never got a new one. i just put it back in when i take it out. lol
Old Oct 21, 2008 | 10:00 PM
jimmy o.'s Avatar
I beleive the B18b1 came in the 94+ acura integras also are you running obd1 or Obd2
Old Oct 21, 2008 | 10:01 PM
Default Re: dumb questions need answered too! (slo_hatch)
i have no idea?>lol
whats the easiest way to tell?
Old Oct 21, 2008 | 10:03 PM
slo_hatch's Avatar
Default Re: (jimmy o.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy o. &raquo;</TD></TR><TR><TD CLASS="quote">I beleive the B18b1 came in the 90-91 acura integras also are you running obd1 or Obd0</TD></TR></TABLE>
no...
b18a=90-93 integra ls, rs
b17a?=90-93 integra gsr
b18b1=94-01 integra ls, rs
b18c1=94-01 integra gsr
b18c5=97=01 integra type-r
i believe that is all of the codes for the integras...
Old Oct 21, 2008 | 10:06 PM
jimmy o.'s Avatar
typo i already corrected it
slo_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92egcivicls &raquo;</TD></TR><TR><TD CLASS="quote">i have no idea?&gt;lol
whats the easiest way to tell?</TD></TR></TABLE>
what do your ecu plugs look like? are there 3 completely square or are they 3 rectangle plugs...on tiny one, one in the middle, and one long one? if it is completly square it is an obd2, if it is 3 different plug sizes its obd1.
Old Oct 21, 2008 | 10:08 PM
slo_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy o. &raquo;</TD></TR><TR><TD CLASS="quote">typo i already corrected it</TD></TR></TABLE>
Old Oct 21, 2008 | 10:09 PM
jimmy o.'s Avatar
how many plug are on your distributor one gray plug is obd2 2 gray plugs is obd1
Old Oct 21, 2008 | 10:10 PM
iamthefollower's Avatar
it doesn't really matter if the motor is obd1 or obd2 as long as it is a b18b1 he can just tell them he needs a valve cover gasket and throttle body gasket for a 1994 acura integra LS.
Old Oct 21, 2008 | 10:16 PM
Default Re: dumb questions need answered too! (iamthefollower)
OK so i just checked the car itself is obd1,but i only has 1 grey plug on the dizzy?
and also notice the unhooked sensor on the intake manifold?
does this mean the motor itself was originally obd2 and wired into the obd1 harness?
so when i order sensor's and stuff do i order for them later year integra's obd2?
Old Oct 21, 2008 | 10:33 PM
slo_hatch's Avatar
how did you check the car itself? if it is before 1996 it is obd1...and you can swap an obd2 motor in and leave some plugs unhooked...just make sure they arent supposed to be hooked up. like my hatch has an extra plug for an o2 sensor but i bought a subharness that had another one...so my old one is just chillin. lol
Old Oct 21, 2008 | 10:36 PM
ok i get it now,thanks for all your help slo hatch!!!
the motor is obd2 wired into the factory obd1 harness.
i have no cel's so i assume everything is fine,agian thanks for your help!
what year did they change to odb2? so i if i have to order a sensor or something ill know.
Old Oct 21, 2008 | 10:38 PM
there should be a number stamped on the head, it'll be like 96 or 99 something like that on the little graphics on the head, it'll be the best way to find out if the motor is obd1 or obd2, if you can get a straight pic shot of the head like looking at straight to the header if you were in front of it, I could tell you what the yr is.
Old Oct 21, 2008 | 10:39 PM
slo_hatch's Avatar
no prob man. obd2 started in 1996...it is obd2a and they have obd2b...i think it started in 2000 (not real sure about that one). but just tell them 96 up and you should be good to go. i dont really know what the difference is between obd2a and obd2b. lol
Old Oct 21, 2008 | 10:40 PM
they have obd2a from 96-98 and obd2b from 99-00
Old Oct 21, 2008 | 10:51 PM
my camera is out of batteries but i just hit the head with a wire brush,and on the first set of symbols i got 00 so its from a 2000?
other then that their was a p75-5 stamp,H.M. stamp and some jap lettering,lol
Old Oct 21, 2008 | 10:53 PM
slo_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower &raquo;</TD></TR><TR><TD CLASS="quote">they have obd2a from 96-98 and obd2b from 99-00 </TD></TR></TABLE>
thanks for clearing that up.
Old Oct 21, 2008 | 11:08 PM
lol on to the next dilema,,
when a b18 swap is done to a eg hatch like mine &lt;92&gt; does it use the stock eg shifter?
reason i ask is i want to order some energy suspenion bushings,but want to make sure im ordering the right parts first,or do they swap the shifter from the teg?or is the stock civic shifter retained?
Old Oct 21, 2008 | 11:19 PM
civicegsick's Avatar
Default Re: (92egcivicls)
the shift linkage would be an LS as well ...
Old Oct 21, 2008 | 11:24 PM
Default Re: (civicegsick)
so i order the shifter bushings for a integra then?
sorry for all the questions,lol
jdmkid_82
Oct 20, 2006 01:48 PM
trickedvtec
Jun 2, 2006 08:14 PM
mcgee*
Jun 20, 2005 01:31 PM
SilverDc2
Dec 23, 2003 06:32 AM
Hard2Find
Apr 17, 2002 07:10 AM
