IAVC code with stock ecu
hey ht I am throwing p1509 code (IAC Valve Circuit Failure) on my 97 civic cx with b18c1 swap could this be due to the fact that the d16y7 ecu is looking for a 3 wire iavc conection to the ecu???
p.s trying to do my best to get the cel off so i can pass emissions
Do not run a B18C1 on a P2E ECU. Get an OBD2A P72 GS-R ECU. You will have to convert the wiring for a 2 wire IACV on both ends of the harness as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazii_boi08 »</TD></TR><TR><TD CLASS="quote"> my 97 civic cx with b18c1 swap could this be due to the fact that the d16y7 ecu is looking for a 3 wire iavc conection to the ecu???
what are you people on? The GSR is one of the more unique B-series motors and needs its proprietary ECU. Jesus H. Christ
I mean Im not tryin to run with the p2e ecu I do have the obd2 p72 ecu it just that on my stock ecu im only throwing one code so i was wondering to see i can get rid of that one code so i can go and pass emissions
zenon8890
Mar 12, 2009 02:21 PM
