need help boosted single cam only boosting 3 pounds why.....
Old Oct 21, 2008 | 06:16 PM
Jdmefsir12's Avatar
Default need help boosted single cam only boosting 3 pounds why.....
i got this cheap turbo kit came with everything front mount turbo wastegate blow off etc..... got all oil lines hook uped got fmu got missing link got a p28 with gsr map single cam vtec supertech valve train with a wild cam.... and for some reason i can only get the car to boost 3 pounds... the waiste gate has no adjustment settings... i am runninng open waistegate it is loud and i was told its not supposed to be loud.... so i cant figure it out but bad waist gate? can someone give me any ideas?
Old Oct 21, 2008 | 06:37 PM
wpgredteg's Avatar
Default Re: need help boosted single cam only boosting 3 pounds why..... (Jdmefsir12)
if wastegate is loud, then it isn't allowing you to build boost.. possibly leaky wastegate. run the car and see if exhaust is coming out the wastegate at idle. otherwise check for any other possible boost leaks
Old Oct 21, 2008 | 07:13 PM
HiProfile's Avatar
Default Re: need help boosted single cam only boosting 3 pounds why..... (wpgredteg)
Mostly all wastegates need the fire ring to work, chances are yours is missing. that will make the WG always leak, and either build boost slowly or not at all. It should blow zero exhaust until you reach full boost (where it will get loud). You could also have a 3 or 5lb spring in the WG. Get a MBC and play with it.
The other part that might be missing - fuel. You DO have an FMU or larger injectors+necessary basemap, right?? It seems like neither, since you don't list an FMU, but list a GSR map. Why would you use a GSR map on a SOHC???
Old Oct 22, 2008 | 11:01 AM
civicjoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmefsir12 &raquo;</TD></TR><TR><TD CLASS="quote">i got this cheap turbo kit</TD></TR></TABLE>
I found the problem
Old Oct 22, 2008 | 03:02 PM
Jdmefsir12's Avatar
Default Re: need help boosted single cam only boosting 3 pounds why..... (civicjoe)
i have a FMU and a blox missing link and a gsr map... the waistegate does leak out the dump tube.... what could it be? should i open it.... there is no adjustment on it and its a 7 pound spring...
Old Oct 22, 2008 | 03:19 PM
LastGenEK's Avatar
You should read the post that people are leaving you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Mostly all wastegates need the fire ring to work, chances are yours is missing. that will make the WG always leak, and either build boost slowly or not at all. </TD></TR></TABLE>
Old Oct 22, 2008 | 06:47 PM
blwn95civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmefsir12 &raquo;</TD></TR><TR><TD CLASS="quote">i got this cheap turbo kit came with everything front mount turbo wastegate blow off etc..... got all oil lines hook uped got fmu got missing link got a p28 with gsr map single cam vtec supertech valve train with a wild cam.... and for some reason i can only get the car to boost 3 pounds... the waiste gate has no adjustment settings... i am runninng open waistegate it is loud and i was told its not supposed to be loud.... so i cant figure it out but bad waist gate? can someone give me any ideas? </TD></TR></TABLE>
Cheap kits usually lead to poor quality products which = Failures... Wastegates are adjusted by spring pressure or boost contoller, they dont have a **** on them
Sounds like to me u need to take the wastegate off and apart... get a good quality wastegate. Unless by open wastegate you mean it dont have a spring in it And of course open wastegate will be loud, its another exhaust pipe for the motor basically.
I'd highly recommend revising your tuning effort
Old Oct 22, 2008 | 07:11 PM
SovXietday's Avatar
Default Re: need help boosted single cam only boosting 3 pounds why..... (blwn95civic)
Lol, missing link, FMU, and a basemap. Talk about cobbled setups.
Stop.
Put everything back to stock.
Read.
Try again when you know what you're doing.
Old Oct 22, 2008 | 07:21 PM
Jdmefsir12's Avatar
Default Re: need help boosted single cam only boosting 3 pounds why..... (SovXietday)
ok look i did not put this motor together,,,,,, so i am getting the after math of all this ****,,,,, i only have built all motor b-series so i am new to the hole boost ****..... so i dont know i did figure since everyone said about the fire ring....... well my **** dont have it cuz there is a gap where the valve in the wastegate on the bottom there is a gap when its closed so i guess i am missing........ something...... and when i mention the fmu and the missing link for this turbo kit and its a computer i had in my hatcb..... so it throws the most fuel for the ecus i have
Old Oct 23, 2008 | 07:35 AM
Make sure not to throw too much fuel tho... dont wanna flush the cyl walls or hurt the future of the bearings.
The reason ppl are bashing your missing link setup is b/c its ancient on turbo setups now. Reason being its not a proper way to go out, drive down the road and try to tune the car by. I know in n/a its not that big of a deal and some ppl are near perfect with it, good tuning software is kinda like insurance for your turbo setup and motor
Old Oct 23, 2008 | 08:25 AM
neoc03's Avatar
1. Cheap parts fail which is more than likely your problem.
2. You need to have a proper tune not a basemap or a all motor tune. Your lucky you haven't hit over 3lbs otherwise chance is your would have heard some awful noises.
3. Get rid of the missing link and get a quality 3bar
4. Research, Study, Research, Study
Old Nov 9, 2008 | 12:40 AM
Jdmefsir12's Avatar
Default Re: (neoc03)
ok well i fxed the racegate problem it is now boosting 10 pounds wich it to much forme.... ineed a manuel boost controller.... so any ideas where i can get one for cheap... yes cheap i am on a budged thianks
Old Nov 9, 2008 | 07:09 AM
SDHonda153's Avatar
Default Re: (Jdmefsir12)
They've got em all over eBay from $5.00 to $600.00
Old Nov 9, 2008 | 07:38 AM
Leland's Avatar
In my personal opinion the wastegate is the singel most important part of a turbo system period. Most people that do these junk yard kits put that $50 xspower gate on their car and they're complete garbage. Get yourself a nice tial 38mm or something of similar quality. You shouldn't be running a gsr map, even a boosted gsr w/stock map will need significant tuning. You need a z6 stock map and then tune it from there. Turbo is a wonderful thing if it's done right and cutting corners will have consequences (your car will never run correctly). Good luck and do a bit of personal reading and you'll be golden.
Old Nov 9, 2008 | 09:15 AM
HiProfile's Avatar
Default Re: need help boosted single cam only boosting 3 pounds why..... (Leland)
Put a Tial on a trash kit, and it will work just as poorly.
My xspower I got for 1/5th of a Tial holds 3psi just as rock-steady as 15psi, and I have datalogs to prove that, not just a cheap gauge. Its all about wastegate PLACEMENT on the manifold. Expensive manifolds usually have some though put into that, cheap logs or cast POS's do no.
pbzhb
Feb 19, 2008 11:50 AM
mkinpwrat12g's
Sep 26, 2005 05:47 PM
psychotic_z
Jan 25, 2004 01:26 PM
JDMs1eeper
Jan 9, 2004 02:31 PM
B20-T
Aug 3, 2002 04:31 PM
