Changing oil filter without draining oil?
Old Oct 21, 2008 | 12:12 PM
Doom325's Avatar
Default Changing oil filter without draining oil?
I had my H23A1 rebuilt about 5000 miles ago and for the last 3000 miles, I have been running royal purple 5w30 (I figured since I spent the money on the motor might as well give her good oil.) I'm going to change the filter in a couple thousand miles (I used a Honda filter) and was wondering if I could avoid having to drain the oil out just to put it back in? Also, does anyone have any recommendations as far as oil filters go? Any input is appreciated!
Old Oct 21, 2008 | 12:58 PM
viper_boy403's Avatar
Yeah it will be fine, just do it when the engine is cold since the oil will have drained down into the oil pan so you wont get as much spillage
Old Oct 21, 2008 | 02:24 PM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Community Influencer
Default Re: Changing oil filter without draining oil? (Doom325)
damn good to know. I stripped the **** outta my drain bolt and can't get it off for a few weeks. I've just been topping the oil up but now a little worried about the filter. I bet it weighs like 10 lbs now :S
I'm going to try this out. I thought that oil would be pissing out the filter hole if I took it off.
Old Oct 21, 2008 | 06:32 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (viper_boy403)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viper_boy403 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah it will be fine, just do it when the engine is cold since the oil will have drained down into the oil pan so you wont get as much spillage</TD></TR></TABLE>
X2
Old Oct 21, 2008 | 07:18 PM
veetak's Avatar
OEM filter. Cut a bunch of them apart with a hack saw, oem is going to be the best quality and construction.
holmesnmanny
Dec 10, 2009 03:14 AM
J.nguyen
Oct 14, 2006 06:04 AM
Sohc Driver
32
Jul 15, 2003 02:46 PM
daLixz25
Jan 5, 2003 06:10 PM
