Fixing a code 92 EVAP Solenoid/Valve/Vacuum Lines
Old Oct 21, 2008 | 11:33 AM
[713]'s Avatar
Default Fixing a code 92 EVAP Solenoid/Valve/Vacuum Lines
Hi i just did the CEL self test on my car and would like to know what exactly it is that im going to repair and how do i go about in doing so
i would really appreciate any help since ive been having this CEL for quite a while now and would like to get it out of the way
Old Oct 21, 2008 | 12:03 PM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: Fixing a code 92 EVAP Solenoid/Valve/Vacuum Lines ([713])
First thing I would do is reset the light and try running a few tanks without filling to the tippy top. My car gets this code 100% of the time when I overfill the tank. However, if I run the last gallon on low speed and don't top it once it clicks, I never get the code.
If that doesn't take care of it, it would be helpful to know the year and engine of your car, as well as the exact code with a scanner (should be 4 digit). You can borrow a scanner at autozone or O'reiley's for free and check the code. It will give a more specific diagnostic than the CEL blink code will.
Old Oct 21, 2008 | 12:13 PM
[713]'s Avatar
Default Re: Fixing a code 92 EVAP Solenoid/Valve/Vacuum Lines (Vindicator9000)
cool thanks a lot will do as soon as i get the chance
edith its for a 95 Civic DX SOHC non-vtec 5spd
Modified by [713] at 1:18 PM 10/21/2008
Bunger
Sep 12, 2011 09:00 AM
karrar55
Aug 29, 2009 04:52 AM
ImprtTunr
Jul 12, 2002 01:47 PM
