Help with CEL code.
Old Jul 11, 2002 | 05:00 PM
ImprtTunr's Avatar
Default Help with CEL code.
So Im at work and my friend says his '95 Accord is idling funny (fluctuating up and down) So I told him I would pull the code for him. I got 7 long flashes followed by no short flashes (70?) So I then took that info to c-speed racings site to get the code definition and it comes up as an auto tranny malfunction, but the chart does not list that code to apply to the Accord. So my question is, is that the right code/definition for his car or is it something else? Your quick response is appreciated. Thanks guys.
Old Jul 11, 2002 | 05:04 PM
scrubachu's Avatar
Default Re: Help with CEL code. (ImprtTunr)
it doesnt go up to 70.
Old Jul 11, 2002 | 05:07 PM
ImprtTunr's Avatar
Default Re: Help with CEL code. (scrubachu)
Ummm.......seven long flashes followed by 0 short flashes I believe indicates 70, and according to c-speed racing there are codes up to 92, there is a code for 70. I was not sayin it flashed 70 times.
Old Jul 11, 2002 | 06:10 PM
Chiovnidca's Avatar
You'll need to check the trans code. What code does the D4 light flash? Or does it have an LED in the control unit? I'm not sure. Either way we need the tranny code.
Old Jul 11, 2002 | 06:20 PM
ImprtTunr's Avatar
So youre sayin that the trans light will flash too? Ill go see what I can figure out. Be back in a bit.
Old Jul 11, 2002 | 06:57 PM
ImprtTunr's Avatar
Default Re: Help with CEL code. (Chiovnidca)
Damn my friend is a riceboy, hes got one of those damn chrome gauge insert things so hes gonna pull it out and Im gonna check the code on it tomorrow. But it is definately a tranny problem right?
Old Jul 12, 2002 | 02:23 AM
niedejb's Avatar
Once you figure out the code try here.
http://home.insightbb.com/~niedejb/refs2.html
Old Jul 12, 2002 | 02:37 AM
Big James's Avatar
New User
Maybe it could be code 7? Code 7 is the throttle postion sensor. If that is faulty, that oculd explain a flucuation at idle.
Old Jul 12, 2002 | 10:56 AM
Jason kiDD's Avatar
Default Re: Help with CEL code. (Big James)
The only time you count the long flashes as 10 is if its followed by short flashes. So if you get only 7 long flashes then Big James is right, its the TPS sensor. It is either faulty or the wiring is loose. Either way get it checked out...
Old Jul 12, 2002 | 01:47 PM
Chiovnidca's Avatar
Default Re: Help with CEL code. (Jason kiDD)
If so, then how does the ECU display codes 10, 20, 30, 70, 80, and 90?
Austin Evans
Jun 9, 2013 06:30 AM
frankenstienEk
Dec 1, 2009 09:26 PM
Allan17
Aug 15, 2009 07:58 PM
97teg415
Jun 1, 2008 07:03 PM
