Will a b16 stock header bold up to a d16y8 stock exhaust system?
basically dropping in a b16a2 complete into a 98 civic ex coupe. will the header line up and fit with the stock d16y8 exhaust? maybe need a new donut to ensure the seal?
thanks, any insight is appreciated
* B A N N E D *
Re: (jrivehard)
i miss read what was wrote yes the b16 headers will bolt up to your stock civic exhaust
Modified by solturbob16sol at 2:56 PM 10/21/2008
Re: (solturbob16sol)
The others who replied didn't understand the question. I think the OP is asking if the B16a header will bolt up to the stock exhaust. I don't know but if it doesn't, an exhaust shop should be able to do it for cheap.
318 Curves, 11 miles
Re: (Black4thgenEF)
I'm not sure about a B16, but on a B18, the tabs on the flange are opposite the tabs on the stock d16y8 flange. Also, the stock exhaust is a little too short. When I did mine, I had to take it to a muffler shop and have the guy cut the flange off the cat, weld in another 2" of pipe, and turn the flange 45 degrees. Then it fits. He charged me $20 for it and took about 20 minutes.
I think the B16 has the same type of flange as the gsr header, so I think you'll have to do the same.
Re: (Vindicator9000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vindicator9000 »</TD></TR><TR><TD CLASS="quote">I'm not sure about a B16, but on a B18, the tabs on the flange are opposite the tabs on the stock d16y8 flange. Also, the stock exhaust is a little too short. When I did mine, I had to take it to a muffler shop and have the guy cut the flange off the cat, weld in another 2" of pipe, and turn the flange 45 degrees. Then it fits. He charged me $20 for it and took about 20 minutes.
I think the B16 has the same type of flange as the gsr header, so I think you'll have to do the same.</TD></TR></TABLE>
x1
one thing different about above is that you won't have to cut. comming from experince, the down pipe section for the b16 header is longer then a b18. only thing that would make this comment different is that the b16 was put in a 93 si(eg). didn't have to cut or anything, just straight bolt on. now i don't know if this well be the same for your 98 ex. the flange might not line up.
x1
Re: (ekhonda87)
>>a b16 header WILL bolt up to your stock exhaust. (i just did a b16 swap into my 98 civic 2 days ago..)
definately makes me feel better about the swap, i'd hate to drive open header
Mr_ET
06-24-2008 06:38 AM
CRXified
04-16-2006 07:38 PM
shadowstylz
07-07-2003 10:05 AM
